Author Topic: So what have you done to your car today?  (Read 6647763 times)
0 Members and 7 Guests are viewing this topic.
« Reply #23685 on: 21 April 2022, 03:07:03 »
Can pay to tighten bolts slightly before trying to back them out. Not a guarantee that they won't still shear, but it can be enough to unfreeze them.  ;)
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #23686 on: 21 April 2022, 09:37:26 »
You might as well anoint them in in Trade Club oil and wear a genuine crank sensor as a lucky charm while you're at it.
« Reply #23687 on: 21 April 2022, 09:54:12 »
It is quite often the difference between unscrewing an Airbus screw and replacing a floor panel because the insert has twisted out.
It hasn't failed me thus far ;)
  • Chatham, Kent
« Reply #23688 on: 21 April 2022, 10:21:11 »
The same procedure is used on external panel screws, after you've dug the grot out of the slots, added some grip paste and found your newest and sharpest screwdriver. Then you get the drill because using an impact driver on thin aluminium parts isn't a solution.
Long steel bolts through tight holes in untreated aluminium suspension components are much harder to drill out ::)
    • Grandland 1.5 diesel
« Reply #23689 on: 21 April 2022, 10:47:49 »
Don't know about tightening first, but I always found a sharp whack to the middle of the bolt head with a suitable punch, followed by a squirt of magic oil did the trick. Sometimes.
Diesel till I die
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #23690 on: 21 April 2022, 12:30:22 »
Tried all of the above, but this thing is beyond any normal level of tightness.
Hub will have to come of, and may well need replacing becuase the threads are shagged.  :(
Rangie
  • Lincolnshire
    • Toyota AygoX
« Reply #23691 on: 21 April 2022, 17:18:22 »
Hitched the tin tent up to the RRS & driven down to a lovely site near Battle visiting friends & relatives , haven't seen one ex forces pal for around ten years looking forward to catching up..🍺🍺🍺
« Reply #23692 on: 21 April 2022, 18:26:58 »
Filled her with petrol....154.9p
« Reply #23693 on: 21 April 2022, 18:28:51 »
Wow! That's pretty good for a tank of fuel.
Diesel till I die
dave the builder
  • Derbyshire
    • omega b2 2.6 cdxi
« Reply #23694 on: 21 April 2022, 19:05:25 »
"HER" is probably a Zippo lighter  :D
« Reply #23695 on: 21 April 2022, 19:33:22 »
Roughly £60 for the appreciating classic and £20 to fill the 3 gallon can for the mower.
Viral_Jim
  • Telford
    • Too many, mostly broken
« Reply #23696 on: 21 April 2022, 19:53:21 »
Surely barely enough to cut a fraction of your rolling acres m'lud?  ;)
« Reply #23697 on: 21 April 2022, 19:57:55 »
3 gallon can of fosters for the man who cuts his grass  :y
Diesel till I die
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« Reply #23698 on: 24 April 2022, 17:09:04 »
Started prepping the Boxster for MOT. Started removing one of the rear calipers, which are held in place by a pair of 12mm diameter hex bolts.
One bolt came out without too much effort. The second could only be moved using a two foot breaker bar and all my weight / might pushing on it.
Got to a certain point and then the head wrung off the bolt. Christ knows how I am going to get it out now.
I think I might have to remove the hub so I can hold the bolt in a vice and then unwind the hub from the bolt.  :(
Porsche learnt how to do that from their Audi cousin. Or they found a stash of British Leyland spec bolts.
You haven't lived until you've had to remove a seized Lupo caliper bolt. VW, in their infinite wisdom, having integrated the slider mechanism into the internal allen bolt. Then decided to make them out of Dairylea, sprayed silver.
Meanwhile, in Zeke land, I've now done some brake line plumbing. I would have had it all done but for VX deciding to use two different sizes of union around the system, only one of which I had in stock...
    • 530D M Sport, 330i Coupe
« Reply #23699 on: 24 April 2022, 21:06:15 »
Took the last bits I want to keep as spares off the old daily. Will be scrapping it this week.
