BazaJT
Early Volvo autos used Dexron this was changed in later cars[phase 2's?] to JWS 3309 spec oil whether they then changed it again for the Phase 3 I don't know.Rather than do a complete empty/refill many owners do "sump dumps" where they drain out as much as will come out of the drain plug[this obviously leaves fluid in the torque converter etc]and refill with the same amount as comes out,then run it for a few hundred miles before repeating.They say doing this 3 or 4 times changes out all the old fluid and is less of a "shock" to solenoids/seals than a one hit full fluid change.
biggriffin
Quote from: VXL V6 on 19 October 2022, 16:20:03
Quote from: Marks DTM Calib on 19 October 2022, 15:42:20
There were two engine variants in the D4, 5 cylinder single turbo and 4 cylinder twin turbo, Aisin auto box (as per GM FWD in europe) so pretty bulletproof.
As for the Passat, they always remind me of the Goodness Gracious Me sketch, 'bring me the blandest thing on the menu'
That's the donk.  :)
Just sorting out getting the box serviced which is a little confusing to get the right information as this car is a 'partial facelift' so I think it needs the AW-1 ATF. Servicing instructions also indicate that it needs VIDA and DICE to reset the adaptations and alter the transmission change counter on the TCM. Doing some research it looks like a lot of owners do a few short distance changes to help get the old fluid out of the system.
This is next job on the Saab, Trying to find the correct grade for the box, isn't easy, as far as I know, it's 3309/aw-1 oil,
Which is approx £100,, for 20L on ebay., Will do a dump and flush, 😕
Hoof'land storeman.
BazaJT
A quick check shows that JWS 3309 is correct grade/spec for the 5 and 6 speed  auto box on Volvos.A"sump dump" will drain approx. 3 litres of fluid.Obviously[I'm sure you know this] make sure that you can remove the refill plug before draining anything. :y
Quote from: BazaJT on 25 October 2022, 20:52:05
Got 12L of Volvo 31256775 (Post 2010 Geartronic) from a Volvo dealer, read the same articles on various Volvo forums I think!
Got an MOT pass (no advisories) on the project car, did need a little patch sticking on with the hot metal sparky stick but hey ho, it is 20 years old!
dave the builder
Quote from: VXL V6 on 28 October 2022, 23:37:40
Congratulations on the MOT  :)
I've got to prep mine in the next few weeks for MOT , and 2 of the Astras .....
so expect 40 days /nights of rain (when it's not snowing that is )  :P
Quote from: dave the builder on 29 October 2022, 21:14:17
Oh yes, guaranteed!
Had to fit an ABS sensor on one of the cars, rained the whole time i fitted it, moment I dropped the car back on the ground the sun came out!
Oi! Are you two borrowing my own personal raincloud without my permission  >:(
;D
YZ250
Checked the tyres on the Audi, the fronts are down to just below 4mm so will need changing soon. It's currently shod with Michelin PS4S and they suit this car so that's what will be going back on. The Michelin's ain't cheap but every Goodyear Eagle I've owned has split in the tread groove, I don't rate Pirelli tyres and the Bridgestone's that both the Audi and the BMW left the factory on didn't inspire confidence in the wet.
Quote from: TheBoy on 30 October 2022, 09:58:39
;D
They would return it but no one delivers to Brackley...  :D
Quote from: YZ250 on 30 October 2022, 10:18:05
If that is what works well, makes sense to keep with them.
I use those Pilot Sport 4 on the XJ, and need a pair on the back.  "Only" £250 each :(
Quote from: Doctor Gollum on 30 October 2022, 11:06:05
;D
Only eBay sellers seem to struggle to deliver here.
So don't sell my raincloud on eGay ;D
Coming back from Gixer's, off the lane and onto the main road, tried to apply *any* power just lit up an amber flashy light on the dash.
Bloody useless ditch finders. Landsail I think.
Quote from: TheBoy on 30 October 2022, 18:36:35
Get them hot and drive over some coarse sand to add some bite to them.
That said, turn off the nanny and give it some beans. Then buy some actual tyres.  :D
Migv6 le Frog Fan
Fitted the new camshaft to Pierre, then went to install the seal only to discover I had been sent one that is far too big.
Nothing is ever quick or straightforward with the little pile of French shite.  ::)
