Quote from: STEMO on 24 May 2024, 07:07:03
Quote from: Sir Tigger KC on 21 May 2024, 18:38:18
Checked both cars over and started them up for the first time after having both my hips resurfaced five weeks ago today.  :)
The V70 started first time, but the Mondeo's battery was flat and as I didn't think was a good idea to go hauling batteries out of cars at the moment while on crutches, I jump started it off the V70 and left it running on the drive for half an hour or so. It took a bit of cranking to get it started though.  :-\
Anyway, it should have put enough charge into battery to get it going next week when I can officially drive again.  :y
I missed this post, Tigger.  :( That's quite a big deal with your hips, I hope you are back to your athletic self very soon.  :-*
Thanks Uncle STEMO!  :y
It's not been too bad to be honest, but I've more or less had to learn to walk again.  Getting there though and should be bouncing around again in a few weeks!  :)
Quote from: Sir Tigger KC on 24 May 2024, 11:34:06
Didn't know of this Tig.
Was it necessary because your hips have been 'ground down' through pleasuring the ladies. ;) >:D
ronnyd
When do you restart the limbo dancing Tig? Sounds a daunting procedure you've had there, hope you're rocking again soon. :y
Quote from: Field Marshal Dr. Opti on 24 May 2024, 12:12:06
Dysplasia, early onset arthritis, with a bit of femoral acetabular impingements thrown in for good measure.  In fact just like an old dog M'Lud!  :)
Quote from: ronnyd on 24 May 2024, 16:42:08
Limbo dancing?  :o  ;D  Christ I need to get walking properly first!  :D
Although I'm doing a mile a day on my exercise bike.  :y
Quote from: Sir Tigger KC on 24 May 2024, 16:45:31
I misread that and now I can see Tigger Lap dancing. Nooooooooo............ :o
Diesel till I die
Quote from: STEMO on 24 May 2024, 16:47:55
I misread that and now I can see Tigger Lap Crutch dancing. Nooooooooo............ :o
Fixed that for you!  ;D
Lend him your thong. :)
Quote from: Field Marshal Dr. Opti on 24 May 2024, 18:39:57
The bit that went up my crack went crispy and snapped  :(
Diesel till I die
countrywoman
Meanwhile back in the car world----------
Managed to weld the section of Omega door with window motor into the Austin door , powered it up and its in line with glass tracks. Only thing is it goes to low, spot of weld on the gear should work as a stop.
Advisory free MOT on the silver Omega  :)
Viral_Jim
Pulled the reversing camera from the OHs Evoque and it's absolutely goosed. Lashed it back together while I order a replacement.
Migv6 le Frog Fan
Fitted a new pair of Avons to the front of the French Toyota. Was murder on the knees and various other body parts.
I really am getting too old for it.  ::)
ronnyd
Quote from: Migv6 le Frog Fan on 03 June 2024, 22:00:56
Since i went arse over head a fortnight ago i know exactly how you feel.  :D Haven't dared kneel down yet.
