Author Topic: So what have you done to your car today?  (Read 8500122 times)
tunnie and 20 Guests are viewing this topic.
    • Grandland 1.5 diesel
« Reply #27045 on: 27 January 2025, 18:01:51 »
Discs and pads all round and a front wheel bearing on the Bini.
Couldn't change the oil though as whomever last did it managed to weld the filter cap on >:(
Might take it for a blast and try again heated up...
Those alloy filter tops are a Bastard to undo.
It's plastic from the look of it, but it don't fancy tearing the housing off the block trying to undo it ;D
That said I did start to take an angle grinder to the nsf disc because the retaining nut had seized solid. Then I remembered that I was changing that hub so dropped the hub and disc off together instead of taking my face off again ::)
Hmm.....angle grinder would have made for better pics  :-\
Diesel till I die
Rangie
  • Lincolnshire
    • Toyota AygoX
« Reply #27046 on: 27 January 2025, 18:40:25 »
Washed Swmbos car for her, its only the 2nd time since we got it in August, she got it mucky in the rain last week, was going to vacuum it as well but felt the rain starting so tucked it away in the garage .
« Reply #27047 on: 27 January 2025, 19:46:35 »
Wash and vac? Rome wasn't built in a day  ;D
Diesel till I die
« Reply #27048 on: 27 January 2025, 20:08:37 »
That's probably how many times mine has been washed in 2 years....
Rangie
  • Lincolnshire
    • Toyota AygoX
« Reply #27049 on: 27 January 2025, 20:13:42 »
Hate doing half a job, my OCD starts playing up..😂
countrywoman
  • worcestershire
    • skoda yeti
« Reply #27050 on: 27 January 2025, 20:29:47 »
Took delivery of 2 rover v8 engines and an auto box on a pallet, driver managed to get it to the door but his trolley.  didnt like the door step. Had to unload it all ,not so bad as engines in bits and then sit the pallet in my workshop and reload it. 2 engines to make one as one block is bad but has good crank and the other block is good but has bad crank. Should make the Hereford move along nicely.
« Reply #27051 on: 28 January 2025, 20:54:33 »
Well, got it nice and warm and eventually managed to get the cap to undo. Turns out it is alloy. It just had so much oil caked over it that it may as well have been plastic.
Slightly more worrying was having drained almost two litres of oil, it still took four and a half litres to refill it.
Camcover gasket and a bloody good clean before it gets flogged.
Lizzie Zoom
  • South
    • Omega 3.2 V6 ELITE 2003
« Reply #27052 on: 30 January 2025, 17:27:08 »
At last, the sun was shining for the whole day and it was not too cold, and my health seemed up for it...........so changed HBV, changed oil filter and oil.  Cleaned breather system and replaced a section of breather pipe.
Checked also the plug wells, and thank goodness no sign of oil, so could leave the cam cover gaskets for later in the spring/summer.
Finished before the light started to fade, felt exhausted, but pleased and satisfied .  Onto the MOT next week! :D ;)
« Reply #27053 on: 30 January 2025, 17:31:21 »
Surely your French 25 year old toy boy should be doing this for you..... ::) >:D
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #27054 on: 30 January 2025, 18:36:22 »
If the cam cover gaskets arent leaking, why do you want to replace them ?
Lizzie Zoom
  • South
« Reply #27055 on: 31 January 2025, 19:05:00 »
I don’t ……..yet.  But we know that in due course they will need doing so I am now prepared to either do them myself, which I don’t want to, but hey ho, or go to Serek!;) ;)
« Reply #27056 on: 31 January 2025, 20:18:30 »
Removed the airbox from the Mondeo so that I could pull the flat battery out to put it on charge overnight.  ::)
See Pissed Off thread.  :-X
« Reply #27057 on: 01 February 2025, 14:09:05 »
Replaced the fully charged battery in the Mondeo, followed by the airbox.  ::)
Back on the road.  :y
danzigfan
  • Jesenice, Slovenia
    • Omega 2.5V6, 3.0V6
« Reply #27058 on: 01 February 2025, 14:34:54 »
Paseed MOT today :D Another year of motoring  :y
« Reply #27059 on: 01 February 2025, 15:07:31 »
Well done  :y :y
Diesel till I die
