Author Topic: So what have you done to your car today?  (Read 8484647 times)
0 Members and 14 Guests are viewing this topic.
countrywoman
  • worcestershire
    • skoda yeti
« Reply #27075 on: 10 February 2025, 11:34:46 »
Bought a new battery charger from Lidl and tested it yesterday, it works. Repaired a beetle indicator switch that had the wires cut off, bit of resoldering.
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
« Reply #27076 on: 10 February 2025, 11:37:14 »
                 I got one of those a few years ago it’s very good👍
Laying a rubber road.
« Reply #27077 on: 12 February 2025, 19:43:23 »
The Mondeo is sounding a bit rough, so went to pop the bonnet earlier and found the bonnet release lever was all loose and floppy.  Apparently the cables are prone to corrosion at the bonnet catch end and snap.  :-\
Bummer.  ::)
Viral_Jim
  • Telford
    • Too many, mostly broken
« Reply #27078 on: 12 February 2025, 19:54:57 »
Only one way to fix the issue then.
Turn the radio up a few clicks  ;)
« Reply #27079 on: 12 February 2025, 20:11:34 »
I was thinking perhaps swapping it for an Astra >:D
« Reply #27080 on: 12 February 2025, 20:13:32 »
A pink one?  ::)
« Reply #27081 on: 12 February 2025, 20:15:22 »
As it's only worth about thruppence halfpenny, that may well be the best option.  :-X
« Reply #27082 on: 12 February 2025, 21:12:30 »
Viral_Jim
  • Telford
« Reply #27083 on: 13 February 2025, 07:29:50 »
Alternatively, should you wish to invest a few minutes of your valuable time, this doesn't look particularly challenging.
https://www.youtube.com/watch?v=3GOAXaMZCl4
I'd probably be inclined to do this and potentially not bother fitting a replacement cable, if you're not planning on keeping the car that long, just leave all the covers off so you can pop the bonnet with a screwdriver when you need to.  :y
« Reply #27084 on: 13 February 2025, 10:20:42 »
Inflation? ::)
« Reply #27085 on: 13 February 2025, 10:43:02 »
Thanks Jim, that's a good find!  :y
I've found a £10.99 repair kit where you feed a new stainless steel cable into the sleeve, rather than replace the whole thing which is a bit of a ball ache apparently.  :)
https://www.ebay.co.uk/itm/121800912239
« Reply #27086 on: 13 February 2025, 11:39:31 »
Inflation? ::)
The Mk4 Mondeo with a transit engine are becoming increasingly rare.  :)
« Reply #27087 on: 13 February 2025, 12:21:34 »
Inflation? ::)
Sorry. My bad. I thought we were talking about the Astra owned by the geriatric scouser. :)
« Reply #27088 on: 13 February 2025, 13:58:18 »
Inflation? ::)
I would have thought that pink Astras are quite rare as well!   8)                                                             Especially in Barnsley!  ;D
countrywoman
  • worcestershire
    • skoda yeti
« Reply #27089 on: 13 February 2025, 14:12:06 »
bought a rivnut kit from Lidl as it has a large handled applicator.
