Author Topic: So what have you done to your car today?  (Read 8484860 times)
0 Members and 31 Guests are viewing this topic.
« Reply #27180 on: 07 March 2025, 13:25:17 »
The F has the ATE type big spring (and they are big callipers on 380mm discs!), its a job I actually wear safety specs for!
I started putty on the full goggles type, as not sure my plastic safety glasses would stop it!  Trouble is, they steam up to easily :(
I might get a full safety mask, as that spring in the chops does smart a bit.
Couldn't you just use your gimp mask?  ;D
How do you know he wears a gimp mask?  ???  :)
Viral_Jim
  • Telford
    • Too many, mostly broken
« Reply #27181 on: 07 March 2025, 13:44:37 »
Pressure washed it ready for sale  >:D
    • Grandland 1.5 diesel
« Reply #27182 on: 07 March 2025, 14:16:13 »
Loo knee told me  :-X
Diesel till I die
Migv6 le Frog Fan
  • Online Online
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #27183 on: 07 March 2025, 14:30:02 »
Washed the wheels on the Boxster. Will finish the job over the weekend, and then start into looking after the Omega again.  :)
« Reply #27184 on: 07 March 2025, 14:51:16 »
Loo-knee was the gimp mask wearer ;D
« Reply #27185 on: 07 March 2025, 14:52:20 »
During lunch, replaced the headlight washer pump, top marks to eBay seller getting it here quickly.
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #27186 on: 07 March 2025, 15:59:05 »
Blimey.  ;D
Migv6 le Frog Fan
  • Online Online
« Reply #27187 on: 07 March 2025, 19:00:53 »
Less than a year ago I fitted a new pair of Halfords H1 dip beam bulbs to my sons Civic.
A couple of days ago he mentioned that the n/s one had stopped working. Found a used one in the shed that worked so fitted that.
This morning he said that one isnt working now either, so fitted another one I had in the shed.
Now all four bulbs (dip and high beam) are on when headlights are switched on.
Switching to main beam changes nothing, and high beam blue tell tale light on the dash doesnt come on.
Dont know where to start to find out why.
Was originally thinking of just fitting four new bulbs, but if theres something else going on, it may blow them in no time and thats almost £50 wasted.
Im not great with electrickery, so any ideas welcomed.
« Reply #27188 on: 07 March 2025, 20:47:03 »
Blimey.  ;D
This has to be a first!  :o  ;D
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #27189 on: 07 March 2025, 21:46:37 »
Blimey.  ;D
He’s got to be on medication to say that,  just got to be.   :o  ;D
« Reply #27190 on: 08 March 2025, 10:20:23 »
Blimey.  ;D
Or he's moved...
ronnyd
« Reply #27191 on: 08 March 2025, 10:34:43 »
Blimey.  ;D
Or he's moved...
Perhaps he's been hacked.
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
« Reply #27192 on: 08 March 2025, 12:17:30 »
Check the appropriate relay,, also might be the headlight dippy flicky bit on the steering wheel.
Hoof'land storeman.
countrywoman
  • worcestershire
    • skoda yeti
« Reply #27193 on: 08 March 2025, 17:38:31 »
Put 10L of fuel in the Austin fuel tank, no leaks from the plate I TIG welded on the bottom where I had to cut a hole to get the swirl pot in.
Migv6 le Frog Fan
  • Online Online
« Reply #27194 on: 09 March 2025, 14:10:55 »
Didnt describe it quite right first time so wil have another go.
Switch headlights on and all four bulbs come on (dipped and main beam) but main beam bulbs are noticeably dim.
Switch to mean beam and both n/s bulbs go off completely but o/s main beam becomes brighter as it should be.
All I did to cause this was change the n/s dipped beam bulb.
The one I fitted was an old spare bulb I had in the shed, which isnt very bright and needs swapping for a decent new one, but I can see why that would cause this to happen.
Im flummoxed tbh.  :-\ :(
