Author Topic: So what have you done to your car today?  (Read 8490119 times)
0 Members and 17 Guests are viewing this topic.
Viral_Jim
  • Telford
    • Too many, mostly broken
« Reply #27735 on: 23 June 2025, 11:34:43 »
The biggest issue with the job is the weight of the assembled struts as you try and d get the nuts started.
Fortunately I was able to balance them on the bottom arms supported by one of those inflatable door wedges to get the top nuts in. My biggest issue was getting the suspension pulled down far enough to get the bottom bolt in.  ::)
« Reply #27736 on: 23 June 2025, 12:09:21 »
Those arm bushes are pretty tight on those... One reason why they handle so well... Life's a compromise.
« Reply #27737 on: 25 June 2025, 15:51:37 »
The Mondeo catastrophically failed it's MOT today.  :(   The End.  ;(
« Reply #27738 on: 25 June 2025, 17:22:07 »
What's killed it? Rust?
« Reply #27739 on: 25 June 2025, 17:30:09 »
Actually that wasn't strictly true, it did fail, knackered front discs and rear arm bushes mainly, and advisories for corroded subframes front and rear, corroded rear arms, and corroded rear springs. He said the subframes had about a year in them.  :-\
What's really done for it though, is a failing dual mass flywheel which accounts for the stiff gear change and vibrations.  :(  The End.  ;(
I was emotional when I posted the MOT fail!  ;D
Rangie
  • Online Online
  • Lincolnshire
    • Toyota AygoX
« Reply #27740 on: 25 June 2025, 18:51:03 »
Upsetting maybe, but time for a new car exciting times ahead treat yourself to something you've always wanted 🚗🚗🚗
« Reply #27741 on: 25 June 2025, 20:08:16 »
https://www.autotrader.co.uk/car-details/202506233799176
Thar do lad. Local and reasonably priced. You'll not miss it long ;)
« Reply #27742 on: 25 June 2025, 21:45:29 »
You never fail us!  :y   ;D
countrywoman
  • worcestershire
    • skoda yeti
« Reply #27743 on: 26 June 2025, 08:56:50 »
Took a Yeti full of rubbish from my unit to the skips, lots of cardboard from new parts for the Austin. I can now open the other door without a landslide! Front wheels in car as well to get balanced when I pick up the rear wheels with new boots on today. Not long now before shakedown runs, bleed the brakes again with only some minute bubbles from front caliper and suspect that was being sucked in around nipple threads. Brake solid but goes quite soft with servo, normal for Omega?
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« Reply #27744 on: 26 June 2025, 10:58:07 »
Yeah, very normal. There is an adjuster under the normal brake pedal that can take some of the slack out but it's the way they're designed.
« Reply #27745 on: 26 June 2025, 10:59:32 »
In fact https://www.omegaowners.com/forum/index.php?topic=90442.0
Viral_Jim
  • Telford
« Reply #27746 on: 26 June 2025, 11:17:42 »
7 Seats is a pretty rare option no? Although I'm not sure how useful the third row is, unless your aim is to make young children and midgets vomit in the boot of your car.  :D
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
« Reply #27747 on: 26 June 2025, 11:23:24 »
Ignore the incorrect torque figure they quote in the ad, in fact it’s 369lbs ft👍
Laying a rubber road.
« Reply #27748 on: 27 June 2025, 13:26:02 »
Ad no longer visible, but I'm guessing some clapped out Merc that will struggle to outlast the Mundano?
;D
« Reply #27749 on: 27 June 2025, 14:01:25 »
;D
What are you hoping to replace the Titty X with, Tig?
......and how deep are your pockets?
