Author Topic: So what have you done to your car today?  (Read 8494454 times)
0 Members and 18 Guests are viewing this topic.
« Reply #2850 on: 24 June 2012, 17:40:42 »
Got a couple of tyres for my wheels. Also spent 3 hours watching 2 exhaust guys trying to fit my eternal back box to the rest of my exhaust. rear pipes on back box was not at the right angle so there needed to heat and rebend them. So glad I did not take up chris gixer on his offer to fit it for me, poor lad would have been there for a week.
Sady that's always a danger when mixing systems. :(
pauls
  • By the sea minehead
    • Bmw x3
« Reply #2851 on: 24 June 2012, 18:13:17 »
I will never learn  :( always seem to do it the hard way. :(
RobseyMV6
  • west sussex
« Reply #2852 on: 24 June 2012, 21:00:19 »
Easy day for me, picked up bonnet and door for a motor i have and fitted  :) all less then a ton :y
All thanks to my local mate's
Also halfords had offer on oil for my V8 so just gave it a treat  :) Could sell it back to them as nearly as clean as it's tipped in the monster every time renew  ;D ;D
« Last Edit: 24 June 2012, 21:04:32 by RobseyMV6 »
Bucko
  • Newark notts
    • 53 2.2 omega
« Reply #2853 on: 26 June 2012, 20:39:23 »
Well after long wait I've got my cam shaft sensor done
The how to guide helped loads  :y very easy fix cost me £ 92
From vauxhall ,starts and revs bang on!!
Steve B
  • Leicestershire
    • '52' MV6 3.2 Saloon
« Reply #2854 on: 26 June 2012, 21:11:29 »
and when they handed it over to you.in your head you said "how the fick can that be worth 10% 5%of my car" ;D ;D ;D ;D
Bucko
  • Newark notts
    • 53 2.2 omega
« Reply #2855 on: 26 June 2012, 21:16:28 »
Yes I did say is that it lol, but sure done the job
pauls
    • Bmw x3
« Reply #2856 on: 26 June 2012, 21:30:03 »
Washed it and put on the new elite wheels. looks tidy now :y
OmegaAnglesey
« Reply #2857 on: 26 June 2012, 21:38:24 »
Changed Air filter genuine Vx  :y  took 3 hours  ;D ... also changed pollen filter genuine Vx 2min job  :y ...
Things to do over next few days, Oil change and filter GM oil bought and Vx oil filter, auxiliary belt ordered waiting for Vx to get in stock, CAT section getting fitted new at a garage, Air-Con re-gas as ATS garage, replacing drivers side headlight, bought some elite wheels to replace GLS/CD alloys,  hmmm think that all for now  :y :y
« Last Edit: 26 June 2012, 21:40:49 by OmegaMan2.2 »
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #2858 on: 26 June 2012, 21:43:08 »
Not done owt to em today, however looking at a big puddle of coolant under the mv6 this morning, i think i will be busy soon. :(
« Reply #2859 on: 26 June 2012, 23:26:39 »
Yesterday, I removed the tow bar....
( But to do that I had to remove the LPG tank some idiot  ::) had installed in the boot, in order to get to the rear tow bar bolts in the boot floor. Tank moved over, frame pulled out from under it, carpet lifted. Went under to undo the tank nuts, only to see a single bolt that fixes the under tank bar, to a seperate u shape bracket to chassis. So I'd disturbed all the tank gubbins for nout.
Then had to re route the LPG filler pipe and got all sorts of crap stuck in the bore. Cut the crossmember with an angle grinder, cut some more...nope...still more. Re solder the trapped earth squashed by the tow bar fitters. Swap the sensor holders over, fit the flip up number plate, put the bumper on and off 50 times to fiddle with this and that. Cut the foam insert, cut it some more, bin it as it won't fit....9 fe@ckin30pm I finished.  >:(  )
...in order to fit irmscher rear bumper and exhaust. A simple job really. ;D
The bumper and exhaust I've had in the garage for 18months bit couldn't face fitting for some reason. ::)
Steve B
  • Leicestershire
« Reply #2860 on: 27 June 2012, 09:22:06 »
its only been in 5 mins  ;D ;D ;D
flyer 0712
« Reply #2861 on: 28 June 2012, 15:04:18 »
Changed rubber exhaust mountings as others were perishing and wax oiled the underneath...rotten filthy job but satisfied when job done  :y
« Reply #2862 on: 28 June 2012, 17:28:36 »
From the car, cube, from the car. ;D
Carefull you'll start Groomer off again. ... :'(
JB1977
« Reply #2863 on: 28 June 2012, 17:40:47 »
replaced parts on one and scrapping another! ;D ;D
« Reply #2864 on: 28 June 2012, 20:33:28 »
On a similar note ::) ;D
