Author Topic: So what have you done to your car today?  (Read 6909107 times)
0 Members and 14 Guests are viewing this topic.
« Reply #3090 on: 12 August 2012, 13:22:58 »
Got halfway through replacing the rear window mechanism in the Silver Bullet when the heavens absolutely opened.
I'll have some din-dins, then tackle it again when the rain stops.
jibberwobble
  • swindon
    • 3.0 MV6 Estate 2000 W
« Reply #3091 on: 12 August 2012, 15:59:15 »
today doing an ashtray conversion so I have two (fused) and hardwired permanent live phone chargers that neatly tuck away ........ this is bound to go wrong!
It works  ;D
geoffr70
  • Sunderland
  • Boobies
    • F/L 3.0 Elite, 3.0 MV6
« Reply #3092 on: 12 August 2012, 17:42:38 »
Fixed a few niggles.
Replaced front pads with genuine as I broke anti rattle spring on last lot and it was annoying the hell out of me.
Stopped the door pins rattling by using clear silicone. And the bloody passenger door card. It's bloody impossible to get those things back on properly after removing them.
Changed drivers side mirror full assembly.
Changed wiper blades and adjusted up nicely. Still too much play in mechanism. Flat wiper blades off eBay are crap btw.
New terminals on pos and neg as wire had corroded inside factory crimped terminal and didn't exactly look easy to get out and reuse. Turns over faster than a fast thing now.
Cleaned birds mess off window.
Tidied boot.
Bah
TC and BnQ Trade holder.
« Reply #3093 on: 12 August 2012, 18:03:49 »
Replaced rear window mech on Silver Bullet. Then went around the usual places with mould killer. Thne washed it.
« Reply #3094 on: 12 August 2012, 18:14:38 »
Washed it...? No WAY! ;D
plym ian
  • Plymouth, Devon
    • 2.0 insignia elite tourer
« Reply #3095 on: 12 August 2012, 18:17:14 »
spent 3 hours to change a track rod end. the bugger wouldn't shift (smacked my hand a dozen times ouch :'() even though I had ball joint splitter, managed to finally get it of by taking center rod off it was out within 30 secs even though n/s was easier done 15 min. I now know that every bolt in steering is super tight :y
« Reply #3096 on: 12 August 2012, 18:31:58 »
I hope you remembered to seal up all the holes first, else you'll have to drain it before you can go anywhere ::)
PFL is far superior as a sieve :y
« Reply #3097 on: 12 August 2012, 18:33:41 »
Just to annoy ianu, I used the tried and tested "one bucket method" ;D
« Reply #3098 on: 12 August 2012, 18:34:59 »
 ;D
Olympia5776
  • Ireland
« Reply #3099 on: 12 August 2012, 18:47:39 »
Had a problem with the Manta on the local annual Opel run yesterday. Smelled  hot antifreeze and stopped to find a little drip from the thermostat cover /hose clip. Tightened it and it started to run out and nothing could stop it. Found >:( that the alloy housing had corroded leaving nothing for the hose to clamp onto and when I tightened it it crushed the remaing casing. :'(
Managed to get it home and swapped over to the Omega and completed the run ... :)
Decided to do the job right and went through all my parts store and found new OE water pump, thermostat , thermostat housing and a full complement of gaskets to suit. Checked all the hoses and have selected better used ones from stock .
Thoroughly cleaned the residue of  the leaked coolent from every surface it splashed onto
As I am planning on selling the Manta after 35 years ( BMW 635 a 'calling  8) )I thought it would be better to get the engine bay back to concours for sale. So most of the ancillery items have been removed for refurbishing and to allow me access to touch up engine block etc.
Found two wishbone bushes worn so ordered Poly replacements for them , cracked all bolts for removal.
I think she know's she going so gave me a last kick in goolies .......
markrnorton
  • Essex
    • 2.2 & 2.5 Ginetta build
« Reply #3100 on: 12 August 2012, 19:06:15 »
removed all the existing speakers in the car. they look cheap !  :D
« Reply #3101 on: 12 August 2012, 21:21:18 »
Swapped the wheels back between the cars, so they are no back where they should be...  ...bloody hard work with no orgasmatron
« Reply #3102 on: 12 August 2012, 21:42:50 »
Cycled 7.5 miles to the gliding club, washed & polished the glider and got it ready for its' annual check. Hot work. Had to stop for a beer. Twice. ::). Cycled home, via the shops for mrs. KW. 8.5 miles.
Looked at the Omega.. Needs a polish perhaps... :-\ Naah. Sod it. ::)
jibberwobble
  • swindon
« Reply #3103 on: 12 August 2012, 22:11:17 »
Whats an orgasmatron? or should I not be asking that :P
amba
  • Medway towns
    • German V6
« Reply #3104 on: 12 August 2012, 22:22:34 »
The orgasmatron is a fictional electromechanical device that appears in the 1973 movie Sleeper, which also shows the effects of a related device, an orgasmic orb. Similar devices have appeared in other fictional works. The term has also been applied to a non-fictional device capable of triggering an orgasm-like sensation using electrodes implanted at the lower spine  ;D ;D ;D
Page created in 0.025 seconds with 20 queries.
