Author Topic: So what have you done to your car today?  (Read 6902164 times)
0 Members and 64 Guests are viewing this topic.
« Reply #4335 on: 03 February 2013, 19:13:32 »
'dangle berries'. Broke the friggin headlight on the Bullet. Grrrrr  >:(
Adjuster or more serious?
« Reply #4336 on: 03 February 2013, 21:25:31 »
Kicking it probably ::)
ozzycat
  • chudliegh knighton /devon
    • hyundia i30
« Reply #4337 on: 03 February 2013, 23:56:33 »
Removed Butterflies .
:y :y :y :y :y at bloody last you were giving us blokes a bad name :D :D :D :D :D :D :D
long live the magic tree
its good to be back
ozzycat
    • hyundia i30
« Reply #4338 on: 03 February 2013, 23:59:28 »
:( :( :( you bloody holigan ;D ;D ;D
its good to be back
« Reply #4339 on: 04 February 2013, 07:46:52 »
Ive posted them to you to re-use  :P ;D
« Reply #4340 on: 04 February 2013, 14:20:58 »
All tyres checked , just needed a new one on the rear as advised on mot ...£15 job done  :)
martin42
« Reply #4341 on: 04 February 2013, 15:09:54 »
been to breakers 1st time in a very long time,got some footwell lights,(£25 on ebay),fog light switch,digital dash loom connector and a air temp connector,all for £10 well happy,lights are now fitted and looks good,now sorting out wiring for the new digital dash going in thats replacing the old analogue dash  :y
symes
  • oxford
    • R reg 940 volvo
« Reply #4342 on: 04 February 2013, 16:39:03 »
Went to go out on miggy today-poppin and banging and jerking about :o :o paper-clip test-code 19-crank sensor-so unplugged it= full of oil :o :o must have been from cracked rocker cover ??? So blew it out with airline and job done-so while there moved it to side of bay :y and covered it-wont catch me out again :y :y Now miggy happy and so am I now :y :y
v6man54deg              Geffd
  • Wirral Merseyside
  • V6 man
« Reply #4343 on: 04 February 2013, 17:53:03 »
New drilled and grooved front disks & mintex pads that came with the car - big improvement
V6 problems solved : Worked at the V6 Engine plant for 13 years on durability testing and warranty issues, this job included many trips to Russelsheim, Trollhattan, Michigan, Atlanta,keiserslaughtern.
« Reply #4344 on: 04 February 2013, 18:23:25 »
Replaced one of the headlight adjusters - the one that doesn't (normally) fail  ???
« Reply #4345 on: 04 February 2013, 23:06:14 »
Oil and filter on MX5 and Omega. Plugs on MX5. Checked diff oil on Omega. Hasn't all leaked out of the pinion seal yet. ;D
« Reply #4346 on: 04 February 2013, 23:19:49 »
Back to the drawing board. Tried some modified rearward bushes in some spare wishbones. Failed.
Refit my wishbones tomorrow. Sigh...
« Reply #4347 on: 05 February 2013, 19:33:21 »
Broke the central locking on TBE.
*sigh*, does it ever end.
« Reply #4348 on: 05 February 2013, 20:26:56 »
With alot of kicking and screaming, a pry bar, a grinder and a couple of hammers, dropped the gearbox to change the clutch ::)
Took a bit of a beating to refit it as well, but all done. Do wonder if an auto wouldn't be easier though :-\
Release bearing was not long for this world but the fiction plate was a tad crunchy and polished. All that remains is to refit the propshaft and cats, but they can wait for another, warmer day.  ::)
« Reply #4349 on: 05 February 2013, 21:26:48 »
Was it a figment of your imagination then? :-X ::)
Page created in 0.025 seconds with 20 queries.
