Quote from: EMD on 16 March 2013, 21:15:54
Turned the key and it started  :o Must get wet weather tyres fitted  :P
...sound idea IMO.  :y
IanF
Finally got round to sorting out the broken Bose sound system, Binned the Bose and Put Two amps and a sub, Component speakers up front and some coaxial in the rear, and run by a pioneer Bluetooth Head unit...Happy Days.
mmcg
Changed timing belt on 02 2.2 cdx,cam cover gasket on 01 2.2 estate and found 02 dti estate needs o/s track rod idler arm.
Quote from: chrisgixer on 16 March 2013, 22:01:12
Yep. Waterproof tyres. They're the new winter tyres. :y
Quote from: Kevin Wood on 17 March 2013, 11:16:04
;D
Im sure what ive got on at the minute will cope with the hospital run once a week , just an anti pot hole guidance system needed  >:(
Marie
Checked my oil leveladn topped her up.
does anyone know the useage rate of an omega?
doz
Quote from: Marie on 17 March 2013, 17:29:10
Depends on the if you have one or two free flow cam cover gaskets  ::) ::)
Marie
Quote from: doz on 17 March 2013, 18:37:21
??? how do i tell???
Quote from: Marie on 17 March 2013, 18:47:09
I sincerely hope that was a 'Tongue in cheek' answer Marie, otherwise Doz will be dining out at your expense for a week! :D ;D
On a V6 - oil smoke from under the bonnet at traffic lights, miss-fire, oil on the ground under your car ;D
I imagine it is easy to see if you have (one) leaking cam cover on a 4 pot :-\
How much did you top it up  ??? Mine never used any oil but that was the 3.0  :)
No idea for a 4 cylinder :-\
My old 2.5 v6 had done 200,000 miles and used to use a bit on motorways (approx 1/2 litre in 1000 miles) but didn't use much around town.
My current 2.6 v6 has done 170,000 miles so far and hasn't needed topping up between oil changes (which is nice  :))
Marie
Quote from: PhilRich on 17 March 2013, 19:01:16
yep sure was was multi  tasking  ;D ;D ;D ;D
Quote from: Andy H on 17 March 2013, 19:11:08
Nah there not leaking :y
Quote from: Andy H on 17 March 2013, 19:19:32
[/quote]
this was my thoughts tbh as im doing 500 miles a week topped her up 4 weeks ago and its about 1/2 ltr  :y
adey2
cleaned the scuttle drains out on both cars, changed out the stereo system on the mv6 for my jvc dvd system, changed heater buttons for none worn ones on mv6, adjusted bonnet pull cable and froze myself in process
v6 locking kit , code reader available, engine hoist and engine stand
also has 2.6 mv6 estate 2001, hilux surf 3.0, vectra 2.0 lpg 2000
danzigfan
Changed oil/filter, air filter, pollen filter, spark plugs, purrs like a cat (250.000 km covered till now) :y
