Author Topic: So what have you done to your car today?  (Read 7676477 times)
0 Members and 47 Guests are viewing this topic.
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #4755 on: 29 March 2013, 16:25:00 »
Driven it to Lizard Point, then to the ice cream place on the Lizard penninsula, then to Sithney for a cream tea, then Padstow and then Perranporth for chips, then back to Hayle.
I guess that it is now "The EvenFatterShadow" ;D ;D ;D
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #4756 on: 29 March 2013, 17:36:02 »
Gave mine a quick wash just to get the salt off. But it,s still pretty cold here. :)
« Reply #4757 on: 29 March 2013, 18:15:08 »
Followed a slow 2.2 Estate Sport from way before Faringdon to Tubney, which was first opportunity to overtake. If its a member here, its the right hand pedal :P
adey2
  • nuneaton, warwickshire
  • if all else fails hit it with a hammer
    • 2000 3.0 elite estate lpg
« Reply #4758 on: 29 March 2013, 19:34:13 »
been busy busy busy and frozen,  the elite has had the self leveling shocks removed off rear as way to soft with lpg tank, handbrake adjusted and the exhaust replaced cats back as split on through pipes, mv6 had steering idler changed, was going to do rear brakes but given up due to light, few jobs off my to do list of many
v6 locking kit , code reader available, engine hoist and engine stand
also has 2.6 mv6 estate 2001, hilux surf 3.0, vectra 2.0 lpg 2000
  • Auckland
    • Mazda MPV
« Reply #4759 on: 29 March 2013, 20:07:05 »
Fitted a new radiator.
Took the front wishbones off to fit the polybushes I bought months ago ::)
« Reply #4760 on: 29 March 2013, 20:10:54 »
Whyzatden?
  • Auckland
    • Mazda MPV
« Reply #4761 on: 29 March 2013, 21:20:12 »
Whyzatden?
I am going to fit new rear bushes and ball joints as well.
also- the front bushes in my 'spare' wishbones were so difficult to shift when I tried to remove them that I damaged the wishbones. I have no desire to try to remove the front ones in situ.
« Reply #4762 on: 29 March 2013, 21:24:07 »
new ecu, 3.0 cams, 3.0 inlet installed.. inlet manifold and plenum polished.. will report results next week after dyno.. oil pump serviced..
« Reply #4763 on: 29 March 2013, 22:27:18 »
Whyzatden?
Piece of pee with a jig saw and a hole cutter, half hour a side wb's on the car....but fair do's. :y
  • Auckland
    • Mazda MPV
« Reply #4764 on: 29 March 2013, 23:07:18 »
Whyzatden?
Good point. A hole cutter it is then  :y
I still prefer to work standing upright though  ;)
« Reply #4765 on: 29 March 2013, 23:12:03 »
Whyzatden?
I prefer to spend half hour a side lining down, personally. But each to their own. :y
« Reply #4766 on: 30 March 2013, 09:44:58 »
Was yours a 2.5 (can't remember)?
A new ECU is not needed for the 3l cam upgrade, BTW.
b4ndit
« Reply #4767 on: 30 March 2013, 12:56:03 »
Fitted the rear subframe bushes with poly bushes the old ones were shot all good now  ;D :y
  • Auckland
    • Mazda MPV
« Reply #4768 on: 30 March 2013, 13:34:45 »
Whyzatden?
Hole cutter worked a treat :y it still took the rest of the morning to cut slots in the outer sleeve of the bushes and beat them into submission ::)
Going to drill out the rivets on the ball-joints next. Anyone know what the correct torque is for the bolts on the replacement ball-joints?
« Reply #4769 on: 30 March 2013, 15:18:32 »
There's a thread on here somewhere with the torque settings. Iirc TB posted them.
Page created in 0.025 seconds with 20 queries.
