Author Topic: So what have you done to your car today?  (Read 6908844 times)
0 Members and 25 Guests are viewing this topic.
flyer 0712
« Reply #4920 on: 14 April 2013, 15:06:21 »
Replaced cam cover gasket and spark plugs....on 2.2 omega...genuine parts of coarse and then washed her....great weather to do it in for a change. :y
« Reply #4921 on: 15 April 2013, 14:28:22 »
So far - cleaned breathers,tightened spark plugs to correct torque (they needed it too), changed dispack, just had lunch and am now going back out to replace thermostat.Not sure if I will get it all back together today .Hope I do,as it would be nice to start it up and hopefully find its running as it should.
« Reply #4922 on: 15 April 2013, 14:40:26 »
Got in to the aroma of Gliptone, started it up, drove to town and back again, parked it up :)
STMO123
« Reply #4923 on: 15 April 2013, 15:37:32 »
Your bellend smells of gliptone? :o
« Reply #4924 on: 15 April 2013, 18:30:07 »
Stat changed,but didnt quite get it all back together.Just got to put the plenum back and attach the various plugs/pipes etc.
My old knackered legs had enough by 6pm,so I will finish it off in the morning before work. Im cream crackered.Getting much too old and worn out for it. ::)
Now supping a cold beer. :)
« Reply #4925 on: 15 April 2013, 22:14:09 »
Put summer tyres on (Kumo 31's) then gave trusty steed a damn good jet wash.
Tanked up on gas, worked out mpg. 25 to gallon on last load of gas :)
So aiming for 27 out of this one now. :)
« Reply #4926 on: 16 April 2013, 08:43:11 »
Yep, my misses said it smells better than it did before rubbing the Gliptone in ::)
bigtow
  • rochester kent
  • 2001 3.2 MV6 manual was 2.6 auto
    • x type 2,0d estate
« Reply #4927 on: 16 April 2013, 17:49:18 »
fitted new powerflex front wishbone bushes not as hard as i thought it would be thanks to the guide on here  :y :y :y :y :y
also had a go at adjusting the handbrake shoes what a pita
2001 MV6 3.2 manual been converted from 2.6 auto
« Reply #4928 on: 16 April 2013, 19:20:27 »
Tried a different set of pressures on TBE
martin42
« Reply #4929 on: 16 April 2013, 20:19:42 »
stripped engine down ready for new cambelt,tensioners,water pump,auxillary belt tensioner and new auxillary belt,just awaiting for new parts to be delivered hopefully by saturday  ;D
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #4930 on: 16 April 2013, 20:25:19 »
After passing the spanners to JamesV6CDX fitting the AR35 box to the TD last weekend, refitted the V5 chip last night. I'd forgotten what a difference it makes. It, almost, feels like the V6. ::) ::) ::)
« Reply #4931 on: 18 April 2013, 21:40:14 »
New rear pads on the Estate - total 1 hour, incl finding and putting tools away ;)
« Reply #4932 on: 19 April 2013, 02:59:58 »
New rear pads on the Estate - total 1 hour, incl finding and putting tools away and a forty minute pause for lunch ;)
Fixed that for you :y
bigtow
  • rochester kent
« Reply #4933 on: 19 April 2013, 10:53:40 »
findings so far after fitting the poly bushes to the wishbones are a marked improvement in cross winds and general handling steering feels much more positive only thing is it seems to have highlighted the rear end problems so time to save up for some pedders subframe bushes . are the rear tie rod bushes a common problem and is it worth replacing them as well ?
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« Reply #4934 on: 19 April 2013, 14:27:00 »
All over the last few weeks  ;)
Had to get 2 locking wheel nuts removed from the front wheels because the previous owner didn't leave the key in the car as he said he did  >:( >:( >:(
One of the wheels got a little alloy damage so touched it up with lacquer as a temp measure for protection.
All 4 brake callipers stripped, cleaned / freed up, rubber piston seals replaced on the front and all re built with new pads all around.
Ground the lip off the front discs so the pads fit nicely.
Autobox selector switch stripped, cleaned and replaced.
OEM front speakers replaced with Infinity components.
Finished the lpg hardware swap from the old car.
Now just got to get it mapped  :'(
2nd oil change in the last 1500 miles.
Next on the list ............... fit rear component speakers and maybe a sub in the bose position  :-\
Gearbox oil flush
