Author Topic: So what have you done to your car today?  (Read 7449185 times)
0 Members and 47 Guests are viewing this topic.
« Reply #5070 on: 17 May 2013, 20:42:07 »
Decided that the loose LPG tank had rotated far enough when it was reading empty after 100 miles, so rotated it back where it belongs and tightened the tank straps. ::)
MV6Matt
  • London
    • No car since 2022....
« Reply #5071 on: 18 May 2013, 06:54:21 »
Got the last bulb in the climate control in and found out ways of manoeuvring the vast amounts of redundant wiring so I could get the H/U back in. :-X
Just need the new climate shroud (from Jon) and the reverse camera monitor wired in and I'm done! ;)
Matthew
(thanks Ian)
    • 530D M Sport, 330i Coupe
« Reply #5072 on: 18 May 2013, 13:01:37 »
Oil and filter, coolant top up, brake pipes greased, handbrake adjusted and exhaust rubbers replaced on Mrs VXL's estate. O/S track rod has a little play in it and front discs and pads required soon.... question is, do I fit one of the sets of OEM pads i've got with new discs or TC ones.....
Rog
« Reply #5073 on: 18 May 2013, 14:21:11 »
Took recently acquired MV6 to Tesco for a mini-valet   ::)
YES, I'm a lazy B$"$%&rd   ;)
Iain
« Reply #5074 on: 18 May 2013, 15:51:56 »
Well this morning I stood looking at it for some 10 mins! Man it's good to own a Miggy again! Especially this one! What a credit to its previous owner  :y
symes
  • oxford
    • R reg 940 volvo
« Reply #5075 on: 18 May 2013, 17:59:19 »
couldn't be asked to do front wheel bearing so changed whole hub-took about an hour so not too bad eh :y and before you say yes camber and tracking spot on-easy enough when you got the gear :y
« Reply #5076 on: 18 May 2013, 19:29:16 »
Drove it to a prearranged location to use it to tow a 3.2 elite from there to another location.
Other party wasnt at agreed meet up point.He had decided to wait somewhere nearby which would be easier for me to find. He rang and texted me to let me know,but my phone battery was completely dead so we couldnt contact each other.We then went round in circles trying to find each other,which eventually we did.
Got to where the 3.2 was and opened the boot to get the A frame out.It then became apparent that I had left two of the three parts of it in my shed,so the car wasnt going anywhere.
Albsiemers strikes again.  :-[ ::) ;D
« Reply #5077 on: 18 May 2013, 19:51:51 »
I always carry a backup battery, when I use net and 3G , batteries cant keep long.. and it can cause lots of problems for those occasions :-\
« Reply #5078 on: 18 May 2013, 19:55:59 »
I have nw decided an in car chrger is vital. :y ;D
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #5079 on: 18 May 2013, 20:06:17 »
As is the rest of the A frame if you're going to use it. ;D ;D
TuBy's new whipping boy.
symes
  • oxford
    • R reg 940 volvo
« Reply #5080 on: 18 May 2013, 20:12:39 »
 ;D ;D ;D ;D ;D ;D ;D
« Reply #5081 on: 18 May 2013, 20:19:41 »
Zok seems to be absent but appears from nowhere when theres a p1sstaking opportunity. ::) ;D
« Reply #5082 on: 18 May 2013, 20:20:26 »
 ::) ;D ;D ;D ;D ;D ;)
symes
  • oxford
    • R reg 940 volvo
« Reply #5083 on: 18 May 2013, 20:20:58 »
Hiding behind curtains ;D ;D ;D ;D ;D ;D
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #5084 on: 18 May 2013, 20:27:05 »
But you make it so easy owd lad.
Page created in 0.024 seconds with 20 queries.
