Author Topic: So what have you done to your car today?  (Read 7703073 times)
0 Members and 43 Guests are viewing this topic.
ted_one
« Reply #5340 on: 24 June 2013, 20:45:48 »
Cleaned out the passenger side scuttles on two of the cars..and they were full of crud...really full :-[ one more to do tomorrow,really looking forward to it..not!!
« Reply #5341 on: 24 June 2013, 21:09:33 »
At least you know how to now :y
Just be sure to get the right car though ::)
ted_one
« Reply #5342 on: 24 June 2013, 21:35:45 »
You are certainly right there Al,I did'nt realise how important it is to keep them clear and they will be squeaky clean from now on....guaranteed :y
« Reply #5343 on: 25 June 2013, 13:53:02 »
Nothing , too busy thinking of engine replacement  >:( V6 should make it sit up  ::)
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #5344 on: 25 June 2013, 15:54:34 »
Removed the scuttle, and got two surprises.
Firstly, all the clips were there!
Secondly, power sounder was already disconnected. It's now been removed  :y
Was hoping to find the alarm also disconnected so as to explain why it wasn't working though  :-\
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #5345 on: 25 June 2013, 16:28:28 »
Check the horn itself, I've seen a couple failed now.
TuBy's new whipping boy.
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #5346 on: 25 June 2013, 16:33:43 »
Can I just put an external power across it to test?
Or what would be the best / simplest way to check?
« Reply #5347 on: 25 June 2013, 16:52:10 »
 :y :y
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #5348 on: 25 June 2013, 16:54:41 »
Cheers  :y
I'll get the booster powered up and give it a go.
CaptainZok
  • Bolton
    • 3.2 MV6 Estate
« Reply #5349 on: 25 June 2013, 17:17:00 »
Yup, a beeping noise signifies a good unit. ;D
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #5350 on: 25 June 2013, 17:35:02 »
Well it must have failed, there's nothing from it at all.
Checked my highly technical test kit using a light bulb, which did work. Replacement needed me thinks.
Came to light recently when I was jacking the car up to change a wheel. Car was still locked and the hazards started to flash, though no audible alarm. Now I know why  :)
bored bigyin54
  • south wales
    • black beast
« Reply #5351 on: 25 June 2013, 20:44:37 »
two days ago i sprayed some carb cleaner around the throttle . after taking the plastic breather off . since doing that the service light is staying off . it used to come on be fore i done that . :y :y :y so dont know what i done but if it stays off i'm happy :y
« Reply #5352 on: 25 June 2013, 22:23:45 »
You un-gummed it , probably got a load of crap in it .. best to clean it out  :y
« Reply #5353 on: 25 June 2013, 23:05:41 »
Checked the oil after noticing an oil slick under it in the road. Level was OK.
« Reply #5354 on: 25 June 2013, 23:25:44 »
Pressed the Omega into service again today as the Cav had a flat tyre this morning.
Went to fill it with LPG and noticed that the "filler cap" was missing. :(
Then noticed that whoever used the LPG pump before me had left their cap sat on the pump. :)
  :-X ::) ;D
Page created in 0.032 seconds with 20 queries.
