Author Topic: So what have you done to your car today?  (Read 8493484 times)
0 Members and 7 Guests are viewing this topic.
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #5355 on: 26 June 2013, 01:01:08 »
Pressed the Omega into service again today as the Cav had a flat tyre this morning.
Went to fill it with LPG and noticed that the "filler cap" was missing. :(
Then noticed that whoever used the LPG pump before me had left their cap sat on the pump. :)
  :-X ::) ;D
Sweet! What a result  ;D
« Reply #5356 on: 26 June 2013, 02:27:07 »
  :-X ::) ;D
Wasn't you was it ::)
« Reply #5357 on: 26 June 2013, 09:21:16 »
Nope,different stations and 10 days apart. ;) ;D
« Reply #5358 on: 26 June 2013, 09:46:13 »
I battled valiantly with the Jag rear hubs, refusing to be beaten.. and I won, mwahahaha!
« Reply #5359 on: 26 June 2013, 13:37:16 »
Are you sure ;D
« Reply #5360 on: 26 June 2013, 14:46:29 »
Parked it in a different spot so the seagulls cant dump on it  >:( Was going to pull things off it and investigate , maybe another day  ::)
bored bigyin54
  • south wales
    • black beast
« Reply #5361 on: 26 June 2013, 14:52:54 »
dont matter where i park mine . they still dump on it  ;D ;D ;D
« Reply #5362 on: 26 June 2013, 15:03:24 »
I parked away from the overhead cables and away from the tree and they still dumped on it  :( Im presuming its seagulls by the size of the stuff  :-\
    • 530D M Sport, 330i Coupe
« Reply #5363 on: 26 June 2013, 22:09:40 »
Changed crank sensor on the side of the A40 at Postcombe.
Well... As my tools were in the boot of another car in Solihull, I confess that I had to get the nice RAC man out to actually fit it at the block end while I plugged it in at the top!
Still, at least I had one in the boot, just in case!
« Reply #5364 on: 27 June 2013, 11:52:00 »
Remember to put another in the boot ;D
« Reply #5365 on: 27 June 2013, 20:57:03 »
Another one ordered today from AndyC. Trouble is.... if i'd had my head screwed on i'd have ordered two.  ::)
« Reply #5366 on: 27 June 2013, 22:33:13 »
Dragged one of them up to the front of the house ready for Mr Scrappy to come and collect it,but he didn't turn up when he said he would.Rang me to say he was coming (2 hours late),"no chance mate,I have to go hospital visiting now". Hopefully hes coming tomorrow.If not,my angle grinder is going to be overworked this weekend. ::)
« Reply #5367 on: 27 June 2013, 22:36:45 »
Cut the numbers out of it and leave it in the road :y someone will take it away,  Friday or not :y
2boxerdogs
« Reply #5368 on: 28 June 2013, 11:05:31 »
Changed the ar filter on the 2.6 , expected to take out a really dirty one but pleasantly suprised  clean .
According to service  booklet last changed at 43,968 in 2008 now on 78,500 , removed a genuine GM one & replaced with a genuine GM one, only £20.82 from my local main dealer.
« Reply #5369 on: 28 June 2013, 15:36:04 »
A day late with this but:
Wednesday Amy & I took the rear brakes on the M3 apart and reapplied anti-squeal paste* to try and cure the horrible squeal it's gained since Rockingham; all of the paste had evaporated due to heat  :-[ I also replaced the 'new' calliper retaining springs with the original BMW ones as the dimensions were slightly off on the new ones. That didn't quite sort it so..
Thursday I took the front brakes apart and did the same thing there, squeal pretty much sorted now thankfully!
Today Amy and her little brother washed, polished, vacuumed, upholstery cleaned, tyre blacked, and polished the exhaust pipes on said same M3 ready for me dropping him and two friends off to their school prom later.
Oh and yesterday I realised it may finally be time for a new exhaust on the Omega as one of the exhaust tips now hangs at a funny angle - it rusted to the point it could no longer support it's own weight ;D ;D
*anti squeal paste = copperslip ;D
