Author Topic: So what have you done to your car today?  (Read 7602239 times)
0 Members and 18 Guests are viewing this topic.
« Reply #5580 on: 01 August 2013, 21:51:39 »
problem with Rover-----Bolt that hold distributor came out :o :o so no panic---Drill 10.4mm and fit heli coil---Game on :y :y :y
that'll learn me to have a buick ;D
Talking of which , ive been looking at V8's rover engines but i dont think it will shoe horn in  :( Well not unless you get the plasma cutter on it  :D
Why-----vxr turbo loonacy would bolt into Vecky----oh gawd what have i done :D
 :o
Thats a plan , a few hrs work in the rain should do it  ;D :y
symes
  • oxford
    • R reg 940 volvo
« Reply #5581 on: 01 August 2013, 21:56:29 »
ok mate---got engine crane /portable mig welder/grinder/cutting gear--- :y :y :y
« Reply #5582 on: 01 August 2013, 21:59:33 »
You chop your roof first symes , you know it has to be done . Dont tell the missus though  ::) :-X
symes
  • oxford
    • R reg 940 volvo
« Reply #5583 on: 01 August 2013, 22:03:47 »
She wants me too---its my mates who dont ???
« Reply #5584 on: 01 August 2013, 22:07:22 »
Arh got it the wrong war around  :-X
Look forward to coming over soon mate  :y
symes
  • oxford
    • R reg 940 volvo
« Reply #5585 on: 01 August 2013, 22:13:03 »
yes mate---bbq--in the rain ;D ;D not clearing my shed---there is stuff in there that i aint seen in years ;D ;D
any one with ocd would flip mate ;D ;D ;D
2boxerdogs
« Reply #5586 on: 02 August 2013, 13:15:37 »
Washed & polished the Hyundai Terracan myself (usually washed at local handwash) looks terrific the metallic paint on it has an excellent finish to it..Now treating myself to a beer & a cheese & onion sandwich!!
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« Reply #5587 on: 02 August 2013, 18:57:38 »
Had the 3.2 AC leak tested, and regassed. No leaks so my new compressor and condenser were fitted OK. Now ice cold in the cabin. Hooray!!! :) :) :)
Shackeng
  • Ramsbury
« Reply #5588 on: 02 August 2013, 18:58:49 »
Fitted a tweeter in the pax footwell of the Elite and wired it to my park pilot, which now works. :o ::) ::) ::)
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #5589 on: 02 August 2013, 19:17:49 »
Changed a whole brake pipe from front to rear drives side on the 2.2, What a pig of a job took 3 days in total.
« Reply #5590 on: 02 August 2013, 19:52:20 »
Ill prob have that job to do next year  :(
Humpy
  • Tunbridge Wells, Kent
« Reply #5591 on: 03 August 2013, 17:53:24 »
Got both struts off today to change the springs to cure what I thought was a broken spring (clonk clonk) to find the offside tyre is dangerously worn on its inner edge  :'( Lower arms I thought. Dropped the steering knuckle off both arms and gave them a bit of horsepower, both have play so its off to All German Parts for some Lemforders. Busted both ABS sensors as they wouldnt come out of their holes ("Apply some anti seizure paste when fitting the sensor" it says in the Haynes book. Yeah well, the previous owner obviously didnt!) And cant work out how to get the vertical nuts and bolts undone. Where is the bolt head, is it on top of the subframe or is there a hole in the subframe and the bolt head is recessed? I cant see diddly under the bonnet! Anybody got any pictures of the bolt heads whereabouts?
« Reply #5592 on: 03 August 2013, 19:02:23 »
Got both struts off today to change the springs to cure what I thought was a broken spring (clonk clonk) to find the offside tyre is dangerously worn on its inner edge  :'( Lower arms I thought. Dropped the steering knuckle off both arms and gave them a bit of horsepower, both have play so its off to All German Parts for some Lemforders. Busted both ABS sensors as they wouldnt come out of their holes ("Apply some anti seizure paste when fitting the sensor" it says in the Haynes book. Yeah well, the previous owner obviously didnt!) And cant work out how to get the vertical nuts and bolts undone. Where is the bolt head, is it on top of the subframe or ]there is a hole in the subframe and the bolt head is recessed I cant see diddly under the bonnet! Anybody got any pictures of the bolt heads whereabouts?
Drivers side can be reached from above the engine bay with a couple of long extensions.
Nearside is a dog to do as has to be from underneath and recess is partly covered by the engine mount ::)
When refitting, tighten as per the guide, otherwise you'll be doing them again in a couple of weeks along with more tyres...
Full alignment at Wheels In Motion or similar afterwards as well :y
Humpy
« Reply #5593 on: 03 August 2013, 19:58:42 »
Ok, thanks for the info. I'll take a fresh look tomorrow!
Humpy
Humpy
« Reply #5594 on: 03 August 2013, 20:16:58 »
Just looked at WIM website, its a bit confusing to say the least. They've got dealers who will do the alignment all over the place, are these as good as the full blown WIM sites? There's one in Tonbridge just a few miles from me in Tunbridge Wells...
Humpy
