Author Topic: So what have you done to your car today?  (Read 6506065 times)
0 Members and 12 Guests are viewing this topic.
andyc
  • Norfolk
« Reply #5655 on: 12 August 2013, 10:11:43 »
Stripped the LSD out of the Manta ready for shipping to the USA. Recovery job to collect a broken down mini cab with a duff alternator
Andy
Thetford. Norfolk
« Reply #5656 on: 12 August 2013, 11:23:23 »
Succesfuly got two of the Leyland 680's running on my 'project', first time in ten years or so .
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
« Reply #5657 on: 12 August 2013, 13:32:33 »
Any vibrations (as you increase revs), heavy breathing or evidence of oil leaks behind the fluid flywheel? ;)
« Reply #5658 on: 12 August 2013, 14:47:28 »
The ones on the watercress line certainly generate quite a nasty smelling blue haze from the breather pipes. ;)
    • 530D M Sport, 330i Coupe
« Reply #5659 on: 12 August 2013, 17:58:10 »
Soldered the battery holder back into a key fob. took all of 10 secs!
joshwyatt
  • Oxford
« Reply #5660 on: 12 August 2013, 18:02:49 »
Attempted to remove the alternator on the 3.2 estate. Bagpipes came out easily, and so did the bottom alternator bolt. The top one however isn't as easy. I found it hard to get the ring spanner on the rear bolt to keep it still whilst undoing the front. I think I'll give it another go tomorrow! Trying to get it all ready for the paintshop and then the application of the livery!
« Reply #5661 on: 12 August 2013, 18:02:55 »
Sometimes, to get mechanical strength, I solder in a cut-off piece of resistor leg through the board, then solder battery holder leg to that. Depends how its broken TBH :)
« Reply #5662 on: 12 August 2013, 18:03:45 »
That reminds me. You are missing a part. Its in my car  :-[
(LED display)
« Reply #5663 on: 12 August 2013, 18:11:29 »
Just enough leg left on the holder to tin and plunge into the blob of solder on the board. it escapes me where I left my solder sucker to clean up the hole and remove the end of the leg so that'll have to do!  ;D
« Reply #5664 on: 12 August 2013, 21:34:47 »
Nothing from the breathers, no leaks or excessive smoke and sweet as, just the usual fan drive rattle on idle  :y
symes
  • oxford
    • R reg 940 volvo
« Reply #5665 on: 12 August 2013, 21:59:01 »
took gear box sump off--had lots of messy fun ;D lost a bolt-got stuck on merlins cat flap magnet ???-and he got slightly dirty paws-like me ;D Dee loved his paw prints when he came indoors ;D ;D But all done-miggy happy and me happy too now :y :y
by the way my old oil was nasty--should have done it ages ago :-[ hey how eh :y :y
Seth
« Reply #5666 on: 12 August 2013, 22:12:22 »
The Leyland O.600/O.680s are pretty robust motors, so thankfully, yours seem to be in good fettle ;)
Now, do they have:
a) sump-mounted 'in-line' type injection pumps?
b) sump-mounted strap-fix starter motors?
c) centrifugal oil filters?
« Reply #5667 on: 12 August 2013, 22:29:55 »
All of the above, plus I have two spare engines fully fitted and two that need work
Seth
« Reply #5668 on: 12 August 2013, 22:30:48 »
Now ... what I did to our car today:
Changed the O/S track rod end, due to slight play. Piece of mind for a mere 12 bucks! ;)
Wheel alignment tomorrow.
Then refitted a door speaker cover ... after some 'anonymous' soul kicked it off! >:(
Seth
« Reply #5669 on: 12 August 2013, 22:36:18 »
Now, do they have:
a) Microscopically check that the drive discs (2 pairs of 3 discs) don't have ANY fractures.
b) ^^^          Ditto           ^^^ castings that retain the strap pins to the sump are sound.
c) Might have some waxed canister liners here. Will have a rummage prior to Newent.
HTH :y
« Last Edit: 12 August 2013, 22:47:08 by Seth »
