Author Topic: So what have you done to your car today?  (Read 8405450 times)
0 Members and 41 Guests are viewing this topic.
amba
  • Medway towns
    • German V6
« Reply #6000 on: 22 September 2013, 10:06:41 »
Removed the original rear discs and pads ready for replacing with new later next week when get time from work :( .
Found hand brake shoes had all but fallen apart so as had bought them along with new springs and fittings did a full hand brake service.
Getting there slowly  ;D
« Reply #6001 on: 22 September 2013, 21:32:43 »
Fitted a shin breaker to the DTi ready for collecting the pikey palace next weekend and i've dropped the Rover Coupe Turbo off for an MOT so hopefully i'll be able to put the pushbike back in the shed because my arse is in tatters from the stupid seats they put on them these days :'( ;D
« Reply #6002 on: 23 September 2013, 09:44:57 »
Drove it to work safe in the knowledge that at least that sodding orange light is a thing of the past.
1/3rd of the way there.. Orange light comes on. Pedal trick shows P0420 and P0150. <scratches head>
« Reply #6003 on: 23 September 2013, 10:28:44 »
That will be the Lidl petrol ::)
« Reply #6004 on: 23 September 2013, 10:34:33 »
Petrol? Bah!
« Reply #6005 on: 23 September 2013, 10:35:26 »
Doh ;D
« Reply #6006 on: 23 September 2013, 10:40:43 »
Of course, being that the orange light has been on for the last 100K miles, it may have masked a "pre-existing condition" and it's probably a few months since I last took a look with the Tech 2. Maybe one of the pre-cat sensors has died and the 0420 is historical, from before the sensor move.
Should have taken a look with a Tech 2 before changing anything, I suppose.
« Reply #6007 on: 23 September 2013, 11:12:09 »
P0150 O2 Sensor Circuit (Bank 2 Sensor 1)
Which was one we didn't touch or go near!  ;D
Is the LPG setup ok?
« Reply #6008 on: 23 September 2013, 12:11:21 »
As said, could easily have been a pre-existing condition, as we didn't touch that sensor.
LPG has been tweaked reasonably recently and is working as well as they ever are! Could well be rich/lean on that bank, though, resulting in no sensor activity detected.
Will be trying it on petrol as well, though.
DaveA
  • Leicestershire
    • Insignia CDTI SE 160
« Reply #6009 on: 23 September 2013, 16:48:57 »
    After replacing wish bones last week took motor in today, to have tracking checked, local garage  L&H Service Center. Motor running fine at the moment, (touches wood) :y
Regards
    Dave
« Reply #6010 on: 23 September 2013, 16:56:58 »
The 0420 code is probably just an old one that needs clearing.
IIRC, you have earlier LPG setup that seems to adjust easier and not send the trims off much, but suffers lag?
« Reply #6011 on: 23 September 2013, 17:22:53 »
Yep, that's the one.
Light came on at the same place in my commute that the cat efficiency codes always did, but guessing there's a timeout or temperature threshold on a cold start after which it starts monitoring these things so maybe not such a surprise.
I will have a dig later and see what's what.  Will be easy enough to see if it's got a lazy pre-cat lambda. I suppose I ought to administer an italian tune-up on petrol on the way home.
« Reply #6012 on: 23 September 2013, 17:24:36 »
Like a cup of tea for an ill man, it cures everything :)
« Reply #6013 on: 23 September 2013, 20:58:39 »
Well, it had a stored P0420 and two variants of P0150. Slow response (present) and sensor circuit malfunction (not present).
Fuel trims were minimal, but it had been driven 20 miles on petrol by then.
Sensor response in the live data was perfectly OK. Both pre-cat sensors cycling fine, and the post cats going lean after a little while at a fast idle.
On LPG, the trims were a bit more wayward, up to 12-15% at times. Might benefit from a bit of a tweak of the LPG system. It also idles a bit lumpy on LPG, and has for a while. I do wonder if it's got an iffy injector, but no attempt to isolate it to a single cylinder ever sheds any light. :-\
« Reply #6014 on: 23 September 2013, 21:09:35 »
Bought another Omega blind :-X :-X ::) ::)
