Author Topic: So what have you done to your car today?  (Read 8422470 times)
0 Members and 32 Guests are viewing this topic.
martin42
« Reply #6105 on: 05 October 2013, 20:01:17 »
Taxed the rover,took it for a drive,all seems ok,slight weep on camshaft cover gasket,but that will be sorted when i service it next month,fitted stereo and sounds good,need to install sub box at a later date.
When you hook it off, clean out the breathers, and wash the gauze through (you'll see it, litle one of those kettle antiscaling devices).
Multiple types of cam gasket, I always found I was supplied with the one for dizzy-equipped K series. Hopefully, factors have better info now...   ...yours needs the type with the hole for the cam sensor (and its not easy to cut one in on the wrong type.
Talking of cam sensors, often failed, but no warning light (BMW era ;)). I have a Testbook here if ever you want it checked.
Ok will check that out when i get cam cover off,might have to borrow the book for a bit of light reading sometime if thats ok :)
« Reply #6106 on: 05 October 2013, 20:51:57 »
Testbook is the diags kit. All my Rover 25 workshop manuals were in the garage :(
martin42
« Reply #6107 on: 05 October 2013, 21:04:51 »
Dam that gas cylinder ........
« Reply #6108 on: 06 October 2013, 10:22:41 »
Changed the oil, oil filter, air filter and fuel filter on the wheesel before my rolling road block exercise all the way to Devon next weekend ::)
    • 530D M Sport, 330i Coupe
« Reply #6109 on: 06 October 2013, 17:44:33 »
Removed the air box lid on 3.2 using the lever it till it snaps method (screw heads crumbled away with rust).  :)
Replaced it with new air box lid purchased from Albitz Omega Spares Emporium.
Mr.OmegaMan
  • Middle of nowhere
    • W205 C43
« Reply #6110 on: 06 October 2013, 18:36:33 »
Had a hell of a day, Went for the usual Sunday Cruise and was in the middle of nowhere and felt sharp pains in the stomach area low and behold diarrhoea feeling, Had to find somewhere to pullover in a wooded area and well you can guess the rest, A very unpleasant experience that was   :-[ :( ;D
« Reply #6111 on: 06 October 2013, 18:48:34 »
Watched serek and his brother lift my 3.2 engine into the back of his van.Strong lads those Polish boys. I wanted to help but they told me to fetch a cup of tea ::) ;D
Stripped a load of bits & pieces of the breaker,so its almost ready for the scrappy now. :)
When I tow it off the drive,the horror of the state of the drive underneath it is going to be revealed. ::) :-X :-X
« Last Edit: 06 October 2013, 18:50:10 by Albitz »
« Reply #6112 on: 06 October 2013, 19:00:07 »
You starting a production line of 3.2 vectra b's Serek  ::) ;D
« Reply #6113 on: 06 October 2013, 20:21:33 »
He did mention something about another conversion. ;)
« Reply #6114 on: 06 October 2013, 20:52:15 »
Hmm the mind boggles ? Maybe a mid engine rear wheel drive conversion  ::) ;D
« Reply #6115 on: 07 October 2013, 10:10:55 »
Watched the drivers side headlamp fail on the Omega at the very start of the journey from Solihull home in the dark.. I really am not having very much luck when it comes to cars recently - or anything mechanical, I managed to break the coffee machine at work last week as well!
« Reply #6116 on: 07 October 2013, 10:38:24 »
Bet that went down well ::)
« Reply #6117 on: 07 October 2013, 12:59:43 »
Bled the brakes on a RAV4. Nice easy job,no need for a jack,as its high enough anyway. :)
MR MISTER
« Reply #6118 on: 07 October 2013, 13:12:13 »
Changed the engine oil on my daewoo. Filter at top front of engine, just lean in. No cover under the engine, just stretch under. 5w 30 fully synthetic £20 off ebay. Quick and cheap  :y
MaxV6
  • Oxford UK
    • 2.2SportPremium Jag est
    • Work related forums....
« Reply #6119 on: 07 October 2013, 13:51:35 »
changed number plate light bulbs,   acquired new MOT.....   she lives for another 12 months,    1 pair of advisories,  N/S and O/S ball joint dust covers worn  (but still preventing dirt ingress)
so....  new ball joints it is then.....  at some point.....
