Pages: 1 ... 51 52 53 54 55 56 57 [58] 59 60 61 62 63 64 65 ... 1939   Go Down
Author Topic: So what have you done to your car today?  (Read 6911744 times)
0 Members and 16 Guests are viewing this topic.
« Reply #855 on: 31 August 2011, 16:05:39 »
On Bluey the breaker today - removed driveshafts, diff,cats, gearbox,rad,A/C condenser,airbox,ABS ECU,,wiper motor & linkage and removed/ disconnected everything ready for the engine to come out. Just need to hire a hoist now and lift the lump out. :) Im absolutely cream crackered though. ::)
Some time between now and tue am, I need to change my rear shocks,springs,steering idler and not long after that the n/s camcover gaskets and a service.
Gonna be busy for a while. ::)
« Last Edit: 31 August 2011, 18:33:35 by albitz »
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #856 on: 31 August 2011, 16:17:20 »
Removed the gearbox on my Scoob to get to the clutch.
I have taken a couple of pictures as the  flywheel had quite a few hotspots so thats now at the Skimming Mans   ;D
The pressure plate has a number of cracks in it from the heat I would imagine, good job i have a new one....
The bearing (spiggot bearing if I am not mistaken) makes a terrible sound when you spin it, so got one of those also.....
There is a bolt that i read about that holds the fork in place, a screw in cap behind the starter motor hides it, which then you need to screw a 6mm bolt into the tapped end so you can slide it out, which being honest i would be still there now perhaps ready to get the bottles on it   :D had I not known........
Hopefully all back together tomorrow... :y
« Reply #857 on: 31 August 2011, 17:57:20 »
Scratched my head wondering where all that ATF under the car has come from. Cock.
Time to swap the wheels over then ;)
Hope it's not time to wait until it's pi$$ing down then get the gazebo out again. ::)
That can be arranged, Mr Wood :P
« Reply #858 on: 01 September 2011, 18:40:23 »
Been under the mv6 today, got covered in ATF, so kicked it.
« Reply #859 on: 01 September 2011, 18:45:52 »
If you're ever down this way and want to borrow a pit (so as not to get covered in ATF, for example), you're welcome to stop by, TB ;)
Today I booked it in for an MOT tomorrow.. wonder if it'll pass?
« Reply #860 on: 01 September 2011, 18:53:24 »
Thanks. Only Newent is looking an ambitious journey in it :(
hotel21
  • The Kingdom of Fife
« Reply #861 on: 01 September 2011, 22:49:49 »
Sore toes?  Major question from the sartorial police is.....
Did you have socks on with the sandals?   :o
« Reply #862 on: 02 September 2011, 13:27:13 »
The Omega had it's first MOT (under my stewardship) today.. passed with four minor advisories:
i) Rear brake pipes slightly corroded
ii) Front tyres worn on inner edges
iii) Rear tyres worn
iv) Sill covers fitted
Number 4 made me chuckle, and the others are easy fixes and stuff I had on my list anyway (besides the brake pipes). Time to call andyc and order some service parts!
« Reply #863 on: 03 September 2011, 15:01:30 »
Cant do a lot today as Im at work, but just changed the steering idler (needed for the MOT Tue. am) and am hoping to do a proper job of getting the o/s cat to centre box to seal.I put it together in a hurry a few weeks and its blowing a bit.
Just leaves rear springs and shocks to change before tues, which I might be able to do at work tomorrow, or if not, Monday.
« Reply #864 on: 03 September 2011, 15:04:55 »
Cheats way, or dropping the diff :question
Hannah Judes Dad
    • the misses round the bend
« Reply #865 on: 03 September 2011, 15:59:05 »
Got peed off with it as it wouldn't start (again) must have an electrical fault somewhere as battery is not even two weeks old  :(
0795omega
« Reply #866 on: 03 September 2011, 16:19:07 »
washed and waxed her,lots of looks when out and about then!!
« Reply #867 on: 03 September 2011, 16:26:20 »
Tried various ways and dropping the diff seems easiest tbh. :y
« Reply #868 on: 04 September 2011, 19:22:27 »
Had Joshwyatt`s car on the drive. Stripped out seats, carpets, seatbelts, glovebox, fusebox cover, cubby hole, parcel shelf, doorcards and all lower black trims. Replaced with all the cream/beige stuff from the red Elite breaker. Thanks to Josh for his assistance.
Josh gotta sort airbag light now. All seats & plugs were like for like and the sodding light is staying on >:(
« Reply #869 on: 04 September 2011, 19:24:11 »
Nothing to the Omega.. got the Nissan out to get it ready for an MOT tomorrow and found that the nearside indicator bulb holder is defective, and tin worm has eaten a hole in the drivers sill :(
Can't decide what to do with it, now  :-/
Pages: 1 ... 51 52 53 54 55 56 57 [58] 59 60 61 62 63 64 65 ... 1939   Go Up
