Author Topic: So what have you done to your car today?  (Read 6902351 times)
0 Members and 63 Guests are viewing this topic.
« Reply #9030 on: 18 November 2014, 21:02:40 »
Had to use the battlebus
Living the dream eh  :y ;D
I'll let you into a little secret, but don't tell the others  :-X
The constant ragging I'm giving it is clearly, slowly having an effect.  It will now redline in the first 3 gears (its not happy about it admittedly), and its power range has increased higher up the rev range.  There is still something very wrong, but slowly it's becoming a bit more eager.
Will it improve further, or will I bugger it up? ;D
You know when your next ragging it.... think about those lovely delicate swirl flaps that can't fully open as the inlet is clogged with sticky sooty yucky stuff.
Just a thought like, don't dwell on it!  ;D
I dislike the car enough, if it did let go, apart from the minor inconvenience of getting home, I wouldn't be overly concerned  :-X
I have visions of seeing it dumped in a ditch on one of my journeys through your part of the World.  :D
Its frequently abandoned in one of the carparks in town.  The exciting thing for me is trying to remember which one ;D
Well start at Tiffins and perform a spiral route around Brack encompassing all outlets serving alcohol
In 13yrs of living here, I haven't done a pub crawl of all pubs in the town. Its definitely do-able, its less than 10 (including the hotel)
« Reply #9031 on: 19 November 2014, 17:02:14 »
Removed the glovebox in order to fail to see the hedgehog ::) Eventually liberated said mammal, nowt obvious wrong with it.
Connected motor to nearest convenient power, aka glovebox light :-X motor spun up before quickly blowing the courtesy light fuse ::)
So looks like a new hedgehog required as I can't find any in the garden :'(
« Reply #9032 on: 19 November 2014, 17:10:42 »
Found one last night. I'd have saved it for you if I'd thought. ::)
Might have got a bit smelly after a week or two, mind. ;D
« Reply #9033 on: 19 November 2014, 17:35:14 »
Isn't 30amps enough to keep it ticking over :-\
« Reply #9034 on: 19 November 2014, 18:49:31 »
Decided this morning that it really, really, REALLY needed new glowplugs, seeing as both last night and this morning, it wasn't in the mood for starting ::)
DrAndyB
  • The Wirral / Cheshire
    • 2.5 V6 CDX Manual (MFL)
« Reply #9035 on: 19 November 2014, 19:40:35 »
Fitted my new Leather handbrake and gearstick Gaitors  :y. (Trim special!ist opposite where I work so they re did my original ones as handbrake one annoying me and looking tardy  :y)
Ahhhhh the smell of fresh Leather in the car  :D
« Reply #9036 on: 21 November 2014, 13:59:59 »
Noticed the heater is still luke ish warm even after a year  ::) Must try and get this sorted and stop relying on the heated seat to keep warm  :-\
taitinson
  • Sunny Cornwall
    • 03 2.6 CDX Estate
« Reply #9037 on: 21 November 2014, 17:10:55 »
Ordered a new exhaust as the old one seems to have grown a tail.... wondered why it sounded strange on the way home ::) ::) too much of it trailing behind to cause any blockage me thinks
« Reply #9038 on: 21 November 2014, 17:14:22 »
Changed waterpump on the Bullet at lunchtime. Don't think its cured the issue, but lets see what the morning and a proper run brings  :-\
« Reply #9039 on: 21 November 2014, 17:15:04 »
How not so :-\
« Reply #9040 on: 21 November 2014, 17:18:26 »
How not so :-\
3m round trip to postoffice, got a coolant warning and steam coming from under bonnet still.
Could be as its bleeding, and old residue burning off. Lets see.
« Reply #9041 on: 21 November 2014, 17:56:03 »
Here's hoping :y
« Reply #9042 on: 21 November 2014, 18:18:39 »
Last pattern water pump I got, the gasket was rubbish and leaked straight away. Had to get a genuine one from the stealers.
Water appeared in the little channel in the top of the sump, just to the right of the crank pulley.
« Reply #9043 on: 22 November 2014, 08:59:18 »
That's where mine was appearing, slightly clouding the fact was it was pulling some oil down with it as well, so was usually "oily" as well.
symes
  • oxford
    • R reg 940 volvo
« Reply #9044 on: 22 November 2014, 11:40:00 »
had a serious miss fire on way home Thursday-so last night  i got leads + coil pack off and fitted new leads and pack that's been on shelf in workshop for a few months-started her up today and all good--yes they're genuine parts---get parts and store them-you never know when you going to need them--as most problems occur at night or late sundays >:(
Page created in 0.022 seconds with 20 queries.
