Author Topic: So what have you done to your car today?  (Read 8385612 times)
0 Members and 66 Guests are viewing this topic.
    • 530D M Sport, 330i Coupe
« Reply #9930 on: 12 April 2015, 18:16:10 »
Cleaned breather system trough and trough , took me 3hours roughly, just to help reducing oil leak from cam covers which I fitted a month ago(not oem part but gaskets were in the boot already so I gave it a go). Well gaskets hold for 4 days  ??? than gave up and she lost 1l of oil from then. Why did I even bother with cleaning engine anyway >:( So leak is no smaller although breathers are clean....new oem gaskets are on to do list for next week :(
Check the oil pressure relief valve is functioning properly.
« Reply #9931 on: 12 April 2015, 18:21:10 »
Sanded and polished the headlights on the 3.2 as they were looking rather yellow against the 2.6's headlights.
danzigfan
  • Jesenice, Slovenia
    • Omega 2.5V6, 3.0V6
« Reply #9932 on: 12 April 2015, 18:30:34 »
 :o Where does this pressure relief valve live? Is there any simple way to see if there's too much oil pressure? I've never done than before :-[
« Reply #9933 on: 12 April 2015, 18:43:08 »
You need to hook up a pressure gauge where the pressure switch is fitted (down by the crank pulley). Is the front or rear crank seal leaking at all?
driver115
  • caistor lincolnshire
    • 3.2MV6
« Reply #9934 on: 12 April 2015, 18:48:52 »
Bought some of the "Triplewax" range of car products from Wilkos today - all seemed to be going for a good price :)
danzigfan
« Reply #9935 on: 12 April 2015, 18:51:42 »
I striped down "half of the engine"....(from my point of view), replaced all foir cam seals but crank seal was fine at that time. And cam seals were replaced only because I was allready there so why not...no apparent leak anywhere.  Cam gaskets which are curently on it aren't oem part but were fine for some four/five days then started to leak first the driver side but I thought it was leaking from oil filler nesck gasket so I removed it and placed a cap directly on cover. It was fine again for a day or two than all hell broke loose. Left and right side leaking badly. :( As I need to replace those gaskets with oem parts anyway I'l start with that. That's the only thing that stoped my former 2.0 oil leak after all
« Last Edit: 12 April 2015, 18:59:37 by danzigfan »
« Reply #9936 on: 12 April 2015, 19:04:36 »
Broke the scuttle whilst dusting the engine bay ::) and possibly located the coolant leak... looks like a new drain plug is in order :D
pauls
  • By the sea minehead
    • Bmw x3
« Reply #9937 on: 12 April 2015, 19:50:45 »
Had new rear springs fitted and rear shocks by a very nice man in west sussex. :y
By the way his mam does lovely bacon sandwiches ;D
« Reply #9938 on: 12 April 2015, 20:09:38 »
;D you're welcome :y
Any difference in the way the car drove?
pauls
    • Bmw x3
« Reply #9939 on: 12 April 2015, 20:15:13 »
Yes it felt a lot better without being to hard. :y  Didnt get any knocking from the back so hopefully sorted that to.
« Reply #9940 on: 12 April 2015, 20:21:31 »
Good stuff :y
If the rattle does return it is almost certainly where the tank heat shields meet, so remember the stuff I suggested just to edge the contact points :y
  • Auckland
    • Mazda MPV
« Reply #9941 on: 12 April 2015, 21:04:02 »
Put another 700 miles on it (over 4 days) visiting family.
steve6367
« Reply #9942 on: 12 April 2015, 23:15:18 »
Stripped the front on the 2.5 and removed condenser - I would say its shot!
15 years of crud behind the fans too!
Delroy47
  • Luton
    • 3.2 Elite Estate
« Reply #9943 on: 12 April 2015, 23:53:48 »
Washed and vac  :y
EMD
  • Noofhampton
    • 95t
« Reply #9944 on: 13 April 2015, 16:12:52 »
Shewed next doors cat off the roof again  >:( Getting sick of it now  >:(
Omegatitis
