WHITE DIALS & CHROME SURROUNDS
Started by MikeDundee, 04 March 2007, 14:39:48
MikeDundee
QuoteLove the dials Mike but will you please get a new number plate - the one with the grafitti on it lets your car down  :(
Or you could just photoshop it out  :y
Is that better Chops?....HAPPY NOW :y
Jim
QuoteNow thats a problem, given that I have superglued the glass back on :-X....So to fix it I would need to replace the whole housing, and it just so happens I have a spare but it is Max's., ....Thanks for the advice though Jim, will give that a go.
How did you fit them? did you not remove the whole intrument's panel (just a few screws) and then separate the dials from the surround (also a few screws) place the new dials in position (held in place with a bit of silicone on the back) then do the thing I said earlier about refit the needle's, refit the surround, then refit the intrument panel, then Bob's your uncle :y
No need to reomove the clear plactic or seperate it from the housing
Yeah I see what you mean now Jim, I fitted the whole panel back at once, but yes you are right it can be done without the housing in place, cheers :y
No Problems Mate :y
When are you back up in Scotland as we're having a meet at easter of the Jockular Omega
MikeDundee
#17
No Problems Mate :y
I am in Thailand all next month, so plans are when I get back in may england/scotland and VBOA meet, no plans at the mo for going up to Dundee this year
Chopsdad
Much better, thanks  :) :P
Jay w
how did you get the chrome surrounds to stick.....
I have had a nightmare with mine  >:(
MikeDundee
Quotehow did you get the chrome surrounds to stick.....
Yeah afraid they are a bit of a nightmare as they are not exactly a perfect fit, what I done was stick them on with superglue, taped them in place first, glued them from underneath, let them set...then I took them off this then left the residue, as i decided to spray the housing, then I just done repeated the process again.
Hope this helps, just do one at a time though :y
MaxV6
No problems doing whatever you want to the housing Mike... like i said, the ONLY bit I need back is the Clock assembly itself.,.. for the Mileage... as it's the original one from My Elite.
should you ever need another housing , I have YET ANOTHER spare still anyway....
that spray looks rather nice mate.  I wasn't sure at first, but in your motor, i reckon it's tasty!
Max
MikeDundee
QuoteNo problems doing whatever you want to the housing Mike... like i said, the ONLY bit I need back is the Clock assembly itself.,.. for the Mileage... as it's the original one from My Elite.
Max
No problems Max, I may have a run down to Oxford and drop the clocks back to you tomorrow?
