Pages: 1 2 [3]  All   Go Down
Author Topic: Photos of the LPG job on my car  (Read 11842 times)
Debs.
Re: Photos of the LPG job on my car
« Reply #30 on: 11 March 2008, 13:52:50 »
 [smiley=birthdays.gif] Happy Birthday Danny!  [smiley=birthdays.gif]
Don`t let the LPG woes spoil your special day.  :y
« Reply #31 on: 11 March 2008, 14:24:23 »
Happy Birthday Danny.. [smiley=birthdays.gif] :y
Cav9_4
  • Sutton-In-Ashfield,Notts
  • 2003 Omega 2.6 Elite
« Reply #32 on: 11 March 2008, 23:53:56 »
A bit late in the day,but "HAPPY BIRTHDAY" :y
Cav9_4
« Reply #33 on: 11 March 2008, 23:57:34 »
I think that is an OMVL evaporator - big bugger!
Strange path for the hot water feed.
No injectors :o
Switch to petrol about 10 seconds before switching the engine off to get rid of the gas in the inlet trunking.
If its a single point mixer, is there not a possible case of a big back fire, blowing up the airbox?
Danny - have they installed a metal blow back on the airbox?
(basically a big metal flap on the airbox)
A friend of mine had a single point on his rangie 4.6 v8,had a new airbox every other week,not sure of make but was very problematic
Martin_1962
« Reply #34 on: 12 March 2008, 10:47:12 »
No injectors :o
Better to blow the air box than the inlet trunking
Danny
  • Wigan, Greater Manchester
« Reply #35 on: 12 March 2008, 17:34:53 »
here's the update, i shall first apologise for seriously knowing LESS than nothing about engines, the injectors (yes there are some :D i had a proper look) are strangely mounted right under the 2 big pipes at the front of the plenum, which a mate of mine says means it'll never run right cos the pipe will then be pretty much the length of the plenum, but it definately isnt conflicting with the MAF cos they're still pointing the correct way
they're gonna add the coolant feed T piece (or whatever else to do that job) that i wasnt happy about, and they're gonna have a look at anything else that might cause the rough idle
basically they're gonna put it right, and in the words of my pal, "no wonder it was so cheap, looks like you got your money's worth"
« Last Edit: 12 March 2008, 17:35:34 by D4NNY »
« Reply #36 on: 12 March 2008, 17:46:21 »
Well, good to know you essentially got the kit you paid for, even if it wasn't installed right first time. The vapouriser would have been getting a very poor coolant supply, especially at idle, with that setup so I think what they propose will help.
Make sure they plumb the feed to the vaporiser by removing the pipe from the coolant bridge to the HBV and then plumbing the vapouriser between the bridge and the HBV. This will give you a better coolant flow than using T pieces.
I'm surprised at where they mounted the injectors. There's plenty of room around the plenum to mount them, and the pipes to each cylinder can be kept equal length and much shorter then.
Anyway, I'm sure there are a few of us on here who would be willing and able to help you neaten it up once it's out of warranty.
Danny
« Reply #37 on: 12 March 2008, 18:23:53 »
its been a weight off my mind, i had a feel of the evaporator earlier tho, it's definately getting red hot
apart from the lumpy idle, it runs sweet as a nut
getting a new fuel gauge fitted on saturday too
« Reply #38 on: 12 March 2008, 18:30:45 »
My guess is that the fuelling needs a tweak then.
« Reply #39 on: 12 March 2008, 21:10:44 »
noooooooo!!!
Thats no good, it needs a direct feed from the coolant bridge to the evaporator, and then from the evaporator to the HBV.
Its will always get hot coolant that way....
Martin_1962
« Reply #40 on: 12 March 2008, 22:36:50 »
T pieces do work if done properly
« Reply #41 on: 13 March 2008, 11:54:05 »
Not if its done below the header tank like mine was.
Martin_1962
« Reply #42 on: 13 March 2008, 15:10:56 »
I did mine just before the HBV and return on the heater out - everything works as it should.
They do not need that much flow but do need the temperature
« Reply #43 on: 13 March 2008, 15:14:20 »
What happens with the climate set to cold then?  :-/
Martin_1962
« Reply #44 on: 13 March 2008, 15:27:18 »
All works perfectly - no heater problems, no aircon problems- been converted for 20 months
Pages: 1 2 [3]  All   Go Up
