Author Topic: Some pics of my LPG conversion  (Read 3402 times)
« on: 19 August 2008, 20:39:49 »
Unfortunately there aren't as many as I'd like but...
The ECU in position... Not as much room when you've got SL Suspension ::) ::)
The Vaporiser in position and connected... Got to mind the EGR pipes or it'll melt the rubber hoses
ECU connections. Due to the slight lack of wire in the supplied loom (probably more due to the route I took!!) I actually intercepted the required wires just outside the main ECU plug and soldered them there! It was still a tight squeeze getting the plug back on and the ECU into place.
Diagnostic Plug... Nice and accessible :y :y
You can just make out the vaporiser under the airbox... A very tight fit
The LPG pipe... Protected by some old heater hose to ensure there are no snagging points when I have it inspected :y :y (the COP is a bit vague in the description of acceptable risk of damage to pipeline ::) ::)
Pipe and wiring running front to rear
And finally for this instalment... The engine bay now it's all back together :y :y
I'll stick some more up tomorrow after I've finished the back end :y :y :y
« Last Edit: 20 August 2008, 21:41:12 by Lazydocker »
maria
  • Derbyshire
  • I'm proud to be welsh :)
Re: Some pics of my LPG conversion
« Reply #1 on: 19 August 2008, 21:58:21 »
Good progress....
What's the chances of water ingress with the ECU that low to the ground?
« Reply #2 on: 19 August 2008, 22:45:19 »
Good progress....
It's not actually as low as it looks... Poor camera skills and bad perspective!!  :-[ :-[ It's actually a good 3 or 4 inches higher than the inner wheel arch :y :y :y
I think it should be OK as long as I don't go through any "puddles" deeper than about 9 inches!!! ::) ::)
Dazzler
  • Haverhill, Suffolk
« Reply #3 on: 21 August 2008, 17:02:30 »
Coming along nicely matey :y
Beconboy
  • DAGENHAM
    • 2000 3.0 OMEGA ELITE
« Reply #4 on: 21 August 2008, 21:09:38 »
 :ywell done m8 give yaself a pat on the back ;D
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
« Reply #5 on: 21 August 2008, 21:14:44 »
That looks a nice tidy install there .......I think i may look into getting this done in the future  :y
« Reply #6 on: 21 August 2008, 21:19:12 »
A few more pictures of the finished conversion :y :y :y
The Filler
... And from the inside
Control switch (sorry for the odd angle!!)
Fill pipe (top) and feed pipe in vent tube
The tank in situ
And finally, the view from the back seats
Calibration is easy and it runs with no noticeable difference in power :y :y :y
humbucker
  • Cambridgeshire
    • www.irmscherMV6.com
« Reply #7 on: 21 August 2008, 21:34:06 »
congratulations paul, i'm glad it's all come together for you! any teething problems? looks like a great installation
PM with your requests.
« Reply #8 on: 21 August 2008, 21:41:13 »
Nope... None so far but only really run up and down the road to calibrate it :o :o
