Author Topic: My lightly modded 2.0!  (Read 12906 times)
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
Re: My lightly modded 2.0!
« Reply #15 on: 10 August 2009, 19:12:29 »
i have a boot spoiler ;)
V8!!!!
Lee A
  • Frome, Somerset
« Reply #16 on: 10 August 2009, 19:22:17 »
Top work there for £300! Any pics of the insides?  :)
Brick Tamland
  • Dublin
  • Good one!
    • '98 2.5 Manual
« Reply #17 on: 10 August 2009, 19:24:43 »
Sweet looking car there mate.  :y
Got a couple of pots missing though  ::) ::) ::)
ah, but no pesky oil coolers or DIS packs to keep in the boot!!! 8-)
Everyone has to admit he has a point  ;D
Dont forget crank sensors,a very awkward cambelt, pain in the arse oil filter, cam cover gaskets and an awkward HBV ::) ;D
Saving for one! All donations welcome, ask for details.
ngrainqey
  • rotherham
« Reply #18 on: 10 August 2009, 19:41:03 »
imo 2.0's pi$$ to work on, you should try working on a volvo :P
V8!!!!
Lee A
  • Frome, Somerset
« Reply #19 on: 10 August 2009, 20:56:56 »
Least you get plenty of practice on a Volvo  :P :P :P ;D
tombstone
« Reply #20 on: 10 August 2009, 21:09:40 »
should try working for Mercs then! Pain the butt they are!!! Not as bad as plugs on a 16v Alfa 33 or oil filter on Lotus Elan Turbo's...
tombstone
« Reply #21 on: 10 August 2009, 21:11:06 »
How is the alignment after the drop?  Have you checked it?
yep! Did it at work same morning!
CateraMV6
  • Lake Orion MI, USA
  • 2001 CATERA SPORT
    • 2001 Cadillac Catera SPT
« Reply #22 on: 10 August 2009, 23:26:02 »
Was it far off?  How did you adjust it, because I know the rear doesn't have eccentric bushings for camber adjustment and mine as it is stock is running around 2° camber and its chewing up the tires like crazy. .
A drop of 1" or more will give something close to 3° which will be even worse.
Pete Elite
  • Uxbridge, Middlesex
« Reply #23 on: 11 August 2009, 01:52:20 »
WOW, that looks in showroom condition, nicely done :y.
m1ct
« Reply #24 on: 11 August 2009, 07:12:38 »
Gosh, that's a tidy mig (at least from a distance :P )
Bargain! Well done tombstone :)
tombstone
« Reply #25 on: 11 August 2009, 08:06:27 »
It's not that far out, and as I have a healthy supply of good 17" used tyres, it doesn't worry me!!
Ziad
  • Bahrain
« Reply #26 on: 11 August 2009, 11:05:36 »
Well, he got a point, but still, I'd still go for a 6 pot  ::)
ngrainqey
  • rotherham
« Reply #27 on: 11 August 2009, 18:08:58 »
lol i hate working on it, nothing wants to come apart/undone (its that well put together) ;) lmao so it usually takes longer (to change the clutch you have to lower the engine through the subframe on one side and take both driveshafts out) or to change the spark plugs you have to take off this little cover ontop of the engine (so far sounds easy)... and wrestle with the hard plastic boost pipe running over the top of the engine and then pop a blood vestle trying to drag the little plastic cover out from between the oil filler cap and the said hard plastic boost pipe!
i shall even post a volvo under bonnet shot lol....
V8!!!!
ngrainqey
  • rotherham
« Reply #28 on: 11 August 2009, 18:39:04 »
« Last Edit: 11 August 2009, 18:52:40 by grainqey »
V8!!!!
« Reply #29 on: 11 August 2009, 18:50:04 »
Try working on a T5, they're even harder  ;D ;)
« Last Edit: 11 August 2009, 18:50:17 by LSG_1 »
Pages: 1 [2] 3 4  All   Go Up
