Did a bit of engine detailing to my ex-plod today
Started by damon80, 09 April 2011, 17:27:11
Stu C
#30
Very good results indeed  :y
I did mine at the weekend but it was quite clean so only took a few hours. That must of taken the best part of a day! A credit to your hard work :)
damon80
QuoteTried the Autosol on my throttle body casing tonigjht, and it didn't touch it! Do you guys just use a cloth and elbow grease, or is there a trick I'm missing?  :-/
Yep, just elbow grease I'm afraid matey! :)  But, if yours is really badly marked, would sanding it down gently with some fine-grit sandpaper first do the job??  :-/
Yeah good thinking! Might try some fine wet n dry!!  :y
Just another thought on this Twiglet - before attacking it with sandpaper, try putting the Autosol on a green scouring pad - a bit less aggresive, and it may just do the job  :y
It's a shame you're not a bit closer to this neck of the woods, or else I'd have a do at it for you...
damon80
QuoteVery good results indeed  :y
Cheers Stu!  :y
Aye, about 4 hours of a job it was, but it'd obviously never been done before.  I've vowed to keep on top of it now, so in future it should just be a case of a quick wash-down and polish-up - fingers crossed!
Stu C
Good man :y   I have vowed to do the same. I recon twice a year should do it as the bonnet has a good seal to it :)
twiglet
Are you coming to the essex meet on the 23rd? I'll bring me autosol and the wife's scouring pad....  :y
damon80
Unfortunately not Twiglet - Essex it a bit too far away from Wigan  :o  ;D
twiglet
QuoteUnfortunately not Twiglet - Essex it a bit too far away from Wigan  :o  ;D
Yeah you're probably right! lol.  I've taken a picture on my progress so far with the engine detailing.  I'll post it up later!  :y
damon80
twiglet
Haven't got round to sorting out the throttle body yet, but this is what she looks like at the moment...
(Hopefully someone can re-jig it so that you don't have to click on the link)  :y
