Pages: 1 2 [3] 4 5 6   Go Down
Author Topic: Omega 2.5TD Eurostyle  (Read 31465 times)
Norwegian.Omega
  • Norway
Re: Omega 2.5TD Eurostyle
« Reply #30 on: 03 February 2011, 20:35:08 »
your car looks awsome! where did you get your front? looks great on your omega =)
crossy
  • Ireland
« Reply #31 on: 04 February 2011, 09:28:55 »
Cheers. :)
Got the whoe kit off ebay from ploand. Got the front grill from england.
Drive her straight sideways
crossy
  • Ireland
« Reply #32 on: 06 February 2011, 19:59:11 »
I may Do something about the suspension. The car is too springy and the wheels are hitting the arches. What does any1 recommend I do? Tyres are being shredded by the arches????  :(
Cheers
Stu C
  • Gatwick
« Reply #33 on: 08 February 2011, 14:10:08 »
Roll the arches?
omegabsw
  • Essex
« Reply #34 on: 09 February 2011, 03:05:16 »
What size tyres you running?
The offset on those rear wheels will be low, mine are ET13
crossy
  • Ireland
« Reply #35 on: 11 February 2011, 07:44:06 »
they are 265 wide. Dish is fairly deep on them
omegabsw
  • Essex
« Reply #36 on: 11 February 2011, 09:47:21 »
Drop down to a 245 and you should have less rubbing
crossy
  • Ireland
« Reply #37 on: 18 February 2011, 09:51:04 »
rolling the arches would chip the paint on the arches.
Going down to 245 would help a bit but not enough because the whole rim is out further than the arch and not just the tire.
Thinking of putting in these?
http://cgi.ebay.co.uk/HSD-Coilovers-Vauxhall-Monaro-and-Omega-/190352499293
omegabsw
  • Essex
« Reply #38 on: 18 February 2011, 12:20:40 »
I reckon it would help a hell of a lot, big difference between a 245 and a 265. Even if the wheel stuck out the stretch on the tyre would be enough for it to not catch the arches as much.
The offset on the AZEV's is gonna be low, like ET13 odd low. If you look under the centre caps you shold see it scratched into the metal.
Stu C
  • Gatwick
« Reply #39 on: 18 February 2011, 12:46:07 »
Not if you heat the paint up   :)
« Last Edit: 18 February 2011, 12:46:36 by Stu_C »
Onkel Per
  • Frederikshavn - Denmark
« Reply #40 on: 18 February 2011, 19:16:54 »
The bodykit is a copy of the Steinmetz kit for the pre facelift model.
Steinmetz don't produce the kit anymore  :'( . But the copy can be found on eBay. And the quality is like the orginal.
Not quit sure about the grill (I have one just like it)
crossy
  • Ireland
« Reply #41 on: 18 February 2011, 20:36:41 »
I made one of these arch rollers. So hopefully it works now
ManiacDrifter
« Reply #42 on: 20 February 2011, 17:33:09 »
very nice car!
Ronny Skaug
Norway...
1995 Opel Omega 2,0 Turbo Drift
crossy
  • Ireland
« Reply #43 on: 23 February 2011, 03:11:04 »
Cheers mate
crossy
  • Ireland
« Reply #44 on: 24 February 2011, 20:23:00 »
Not having great luck with this car
>Two alloys buckled and cracked cause of terrible irish roads
>1 Tyre gone cause of irish roads
>Car fell off jack and cracked side skirt
>And Someone Reversed into me in a carpark :(
Pages: 1 2 [3] 4 5 6   Go Up
