my Elite irmscher
Started by serek, 30 August 2009, 15:45:10
Exec
#30
QuoteSerek, what's the top speed (5'th gear rev limit) on this 4.22 diff?
And what do you think about increasing top speed by using a bit bigger wheels (higher profile of tyres)?
top speed on V th gear is about 140MPH.
I try this alredy with mine 19" 235/40/19 clock  say140mph- sat nav 142MPH
on 255/35/18 clock say 140MPH sat nav 137MPH
hope that help :y
all the wheels the same size ?
the diameter of the 235/40/19 is 670.6mm, the 255/35/18 has a diameter of 635.7mm, and the stock 205/65/15 647.5mm
The teoretical calculated diffirence between your 19" and 18" wheels is 1,7mph
Not much :(
I was considering the 4.22 diff, but the top speed is definetly not high enough  ;)
serek
#31
hope that help :y
Not much :(
not check this way, only work out from speedo and sat nav where they not always correct
oh all tyres are same size :y
4.22 is great for 3.0 or 3.2 with auto box :)
V6irmscher
nice car similar to mine :y
serek
Quotenice car similar to mine :y
thanks
hope see you motor at OKP meet on 11.12.10
in Stevenage :y
V6irmscher
thanks
in Stevenage :y
I will definitely come   :y
serek
thanks
in Stevenage :y
see you there :) :y
gerry c
nice motor is the whole bodykit irmy??? that's the look im after
serek
#37
Quotenice motor is the whole bodykit irmy??? that's the look im after
thanks
yes its irmscher body kit  8-)
sotmh
realy nice. I love those wheels :y :y
serek
some up date:
set of 4 pot brembo callpiers and 323mm discs,
will fit them next week when my 18" SS come back frm body shop
Uploaded with ImageShack.us
and some other toys
fast road cams and ECU master
Stallion
The car looks Great, and those brake disc look like they got some serious stopping BUSINESS!!  :y
car-nut
One of if not the BEST Omega I have ever scene! I love it.
Me & My Motors are Truly 1 off's
Are those adaptors man enough?  Seen Beefier on bikes tbh....   :-/
serek
#43
QuoteAre those adaptors man enough?  Seen Beefier on bikes tbh....   :-/
they are big and strong enaugh to do they job on 4 pot calipers :)
adapter for 6 POT
6 pot fitted
serek
some up date
I put my car on RR at santa pod just to check what sort of power I got before I will fit fast road cams and few other bits
finaly got new brake fitted with chocolate bracket  ;)
