F/S Various Omega's
Started by joshwyatt, 02 March 2010, 22:54:47
QuoteI will add that although i normally swear by auto`s a few bits of rapid driving recently in my MV6 auto had me realising how much better it would have been in a manual and at times i was having to back off as i didn`t have the control and there is a big difference when you find the engine revs are suddenly at 3500 when you wanted 5500 and full drive.
Use the "s" button and also shift the gears manually :y :y :y
Generally, for most twisty roads sticking it in 2 will have the desired effect :y :y :y
Agreed 2 & "S" .....   = fun ..  :) :) :) :)
but don't look at the instant fuel consumption whilst doing it !!!!  :-/ :-/ :-/
;D ;D ;D ;D ;D ;D ;D
Bumbazor
QuoteSingle figures?
It bottoms out at 7.1 mpg :o :o  :'( :'( ::) ::)
with ease ...   :)
with ease ...   :)
Pulling that burger van helps  ;D
with ease ...   :)
What do you mean... I can see 7.1 solo :o :o :o
with ease ...   :)
and far to easily !!!   ;D ;D ;D ;D ;D ;D (but its FUN !!!   ;D ;D ;D  )
with ease ...   :)
And (Relatively) cheap with LPG :y :y :y
If anything, that's the biggest down side of it... You don't really worry about running costs ::) ::)
I seem to have suffered screen burn, as mine seems to read 7.1 most of the time ::)
Which must show how good it is on a cruise, as over the last 4000+ miles, my (accurate) CID is claiming 24.2mpg
fletchesmrs
If you need to worry about fuel costs, dont buy an Omega  :y i drive mine cos i love it dont look as fuel consumption, thats sad  :y :y
my 1st omega like a rottweiler on steroids shes a bad b*tch.
damon80
Correction - buy an Omega with a manual box.  Get 38mpg easily out of my 3.2 manual ;)
QuoteCorrection - buy an Omega with a manual box.  Get 38mpg easily out of my 3.2 manual ;)
I can easily see that on a run from my auto, assuming I drive very gently and stick below speed limits  ;) ;) But driving enthusiastically I agree with TB... I reset the Trip Computer every time I fill with LPG and my average is always around 24.4 MPG for my normal commute/town driving which, considering my Instant Consumption spends a lot of time reading 7.1 MPG  ::) :-[ is very impressive.
Normally when I go visiting and on a decent run I see an Average of around 31-33 MPG depending how enthusiastic I'm being :y :y
