Author Topic: FOR SALE - X-REG FACELIFT 3.0 MV6 AUTO OMEGA -FSH-  (Read 2512 times)
Road Hog Mad
  • Cheshire
« on: 09 May 2010, 11:09:02 »
Thought I'd stick it here first before eBay.
Up for grabs is my Omega, a fine example with full service history.
140,000 Miles, regular oil changes, good tyres, tensioner and aux belt just done, new power steering pump, battery and replacement expansion tank, VERY TIDY etc. Just needs a new owner.
Cruise control, after market cd player with mp3 and usb dongle, after market parking sensors, near enough top spec apart from rear blind and sun roof.
Things it has had whilst I have had it...
Replacement ballast units for xenon lights, expansion tank, power steering pump, crank sensor (didn't need one, garage replaced it by mistake), exhaust recycling sensor, tensioner and aux belt, cruise control, new cd player, parking sensors, bypass valve (the one right at the back of the engine), discs and pads, spark plugs, many oil changes, air filter, wipers. Really looked after with the all important service history.
A must see and test drive!
Would consider a swap for an auto diesel something or other.
£1750.
Pics... http://img691.imageshack.us/i/55231915.jpg/
http://img709.imageshack.us/i/90443095.jpg/
http://img265.imageshack.us/i/24095780.jpg/
[size=18]11 Months MOT - Tax: Sept 10[/size]
« Last Edit: 09 May 2010, 11:39:03 by pjwright »
Re: FOR SALE - X-REG FACELIFT 3.0 MV6 AUTO OMEGA -FSH-
« Reply #1 on: 09 May 2010, 12:50:33 »
« Last Edit: 09 May 2010, 12:52:06 by tunnie »
Road Hog Mad
  • Cheshire
« Reply #2 on: 09 May 2010, 17:48:07 »
[size=14]Some service history...[/size]
•      139,056 MILES – REPLACED EXPANSION TANK DUE TO FAULTY ‘COOLENT LEVEL SENSOR’ £27.00
•      138,792 MILES - MOT TEST - 06/04/2010 - 'PASS, NO ADVISORIES' £35.00
•      ??? MILES – NEW BATTERY (3 YEAR WARRANTY) 08/03/2010 £69.99
•      138,480 MILES – NEW BELT TENSIONER, BELT AND POWER STEERING PUMP £425.42
•      137,544 MILES – OIL SERVICE – 14/02/2010 £29.50
•      133,463 MILES - SPARK PLUGS - 22/08/2009 £72.30
•      132,255 MILES - AIR-CON RECHARGE & OIL SERVICE - 26/06/2009 £74.00
•      131,500 MILES - NEW DISCS AND PADS - 01/05/2009 £248.37
•      MOT TEST - 03/04/2009 - 'PASS, NO ADVISORIES' £25.00
•      129,200 MILES – OIL SERVICE – 17/05/2008 £25.00
•      127,400 MILES - WHEEL ALIGNMENT - 15/12/2008 £39.25
•      126,300 MILES - OIL SERVICE & AIR FILTER - 02/10/2008 £33.79
•      11/07/2008 – BY-PASS VALVE £69.02
•      120,278 MILES – OIL SERVICE – 17/05/2008 £25.00
•      120,244 MILES – EVAP VALVE SENSOR – 01/05/2009 £167.49
•      119,983 MILES – CRANK ANGLE SENSOR - 01/04/2009 £120.00
•      112,124 MILES – OIL SERVICE – CAMBELT & KIT – OIL COOLER – CAM COVERS – FRONT SHOCKS – DIFF OIL SEAL – REAR BRAKE PADS – KEY FOB -  CYLINDER HEAD COVER X2 – GASKET - CONTROL VALVE – SEAL RING – SEAL – VALVE NON RETURN – RADIATOR ENGINE – CARTRIDGE STRUT X2 – SEAL - 08/11/2007 'VAUXHALL DEALERSHIP SERVICE' £2,212.83p
•      99,290 MILES – 06/02/2007 'VAUXHALL DEALERSHIP 100K SERVICE' £175.23
•      93,181 MILES – REAR WHEEL BEARING KIT – 14/09/2006 £241.41
•      92,438 MILES – FRONT WHEEL BEARING KIT – 22/08/2006 £239.47
•      90,358 MILES – OIL SERVICE - 17/07/2006 'VAUXHALL DEALERSHIP SERVICE' £144.81
•      80,751 MILES – BRAKE PADS £26.62
•      80,565 MILES – FRONT LOWER SUSPENSION ARMS – 24/11/2005 £265.90
•      79,878 MILES – OIL SERVICE – BRAKE FLUID – SPARK PLUGS – AIR FILTER – FUEL FILTER – POLEN FILTER – 09/11/2005 'VAUXHALL DEALERSHIP SERVICE' £269.39
•      76,765 MILES – KIT-SCREWS – 04/12/06 £25.00
•      74,846 MILES – CAMBELT & KIT – 03/08/2005 'VAUXHALL DEALERSHIP SERVICE' BOOK STAMPED
•      74,824 MILES – VALVE TIMING BELT KIT – 03/08/2005 £272.60
•      63,878 MILES – OIL SERVICE – BRAKE FLUID – AIR FILTER – 28/04/2004 'VAUXHALL DEALERSHIP SERVICE' BOOK STAMPED
•      58,639 MILES – OIL SERVICE – FUEL FILTER – POLEN FILTER – 15/10/2003 'VAUXHALL DEALERSHIP SERVICE' BOOK STAMPED
•      45,781 MILES – OIL SERVICE – BRAKE FLUID – TOOTHED BELT - CAMBELT & KIT– 02/12/2002 'VAUXHALL DEALERSHIP SERVICE’ BOOK STAMPED
•      44,420 MILES – MOULDING CENTER – 04/01/2005 £20.45
•      36,181 MILES – OIL SERVICE - SPARK PLUGS – AIR FILTER – FUEL FILTER – POLEN FILTER – 08/05/2002 'VAUXHALL DEALERSHIP SERVICE' BOOK STAMPED
•      26,927 MILES - OIL SERVICE - 23/03/2001 'VAUXHALL DEALERSHIP SERVICE' BOOK STAMPED
•      19,411 MILES - OIL SERVICE - 14/12/2000 'VAUXHALL DEALERSHIP SERVICE' BOOK STAMPED
•      11,551 MILES - OIL SERVICE - 07/11/2000 'VAUXHALL DEALERSHIP SERVICE' BOOK STAMPED
[size=16]£5379.84 SPENT![/size]
« Last Edit: 09 May 2010, 18:16:45 by pjwright »
