Author Topic: FOR SALE - Omega 2001 2.2 Auto Saloon  (Read 2868 times)
SJKOO01
« on: 13 October 2010, 20:02:39 »
[size=14]Omega 2.2 CD for sale[/size]
Omega 2001 2.2 Automatic Silver saloon for sale
Currently has 99,675 miles on the clock (as of 10th Oct)
May 2009 - Fitted with Gates Powergrip cambelt kit fitted at 89,252 miles.  Along with a new auxiliary belt (timing belt).
July 2009 – Cruise control stalk fitted & activated.
March 2010 - Automatic gearbox fluid check, fresh oil top up, new filter, and thrust washer check done.
May 2010 – dropped suspension 40mm, has Apex springs all around, with FK Automotive shocks all around.
May 2010 - Replaced new camshaft gasket & O-ring seals due to leak (using Genuine Vauxhall set).
July 2010 - Replaced spark plug boots with genuine repair kit.
July 2010 – Boot release modification done (boot release with engine running)
August 2010 – New set of 225 x 55 x 16  95w Milanzah z1 tyres fitted all round
(all currently have 8mm depth of tread).
Sept 2010 – both front wishbones replaced with quality All German Parts items.
Also fitted with MV6 cloth seats (better side supports & adjustable leg support)
Electric motors work without any problems.
Mot till Dec 16th 2010
Tax = None (Currently disabled taxation)
Nearside Bodywork:
Front wing – a few very light surface scratches if you look up close
Front door – as front wing
Rear door – a few very light surface scratches with x1 deep 1inch long scratch in lower level of the door
Rear wing – as front wing + small paint chip, though not rusting just showing primer
Offside Bodywork:
Front wing – a few very light surface scratches if you look close up & slight golf ball size dent
Front door – Ok / fine
Rear door – Ok / fine
Rear wing – Ok / fine
Bonnet – Ok / fine
Boot – Ok / fine
Front bumper – very good condition paint wise, but does have parking lump / crease on front edge, which has broken the paint, been there since I bought it originally, just never gotten around to fixing it !.
Rear bumper – Good condition, though does have few light scratches in paintwork
Roof – Ok / fine
Front & rear lights are in very good condition
O/s outer sill cover has paint chips & some deep scratches around the middle of it.
N/s outer sill cover ok / fine.
Windscreen wiper arms have paint / coating flaking off a little.
Both door mirrors are in good condition, and both have working heating elements & motor adjustments.
Inside / interior:
Was originally a CD spec biscuit / beige colour interior.  I was in the process of changing it over to the black MV6 spec.  So up-to-now I have replaced the carpet replaced with a black one, replaced the front seat runner covers, Inner plastic sill covers, & kick panels with black version.
Glove box is currently the original biscuit / beige colour, along with the door cards, but have black glove box if you want it to change over ?.  I was going to change the door cards to the darker grey / black MV6 door cards with the silver strip, but now will be using them on my other Omega project.
Current door card handles do have ware on them (rubber coating showing signs of wear)
All electrics work as they should.
Aircon works, unit buttons are in good condition, apart from the ‘off’ one, which is now starting to show signs of wear.  The Aircon may need a re-gas soon ?.
Aircon unit, radio centre console, and gearshift console, ashtray cover has been colour coded to car (though ashtray doesn’t currently stay shut when you want it to ?).
Radio slot / panel has been converted to single din.  Unfortunately radio will not be included in sale.
Driver side air vent panel has hole in it, as removed the Traffic Master system, though may change that if buyer wants it replacing ?.
Have to be honest with the work currently needing to be looked at present:
1. Nearside steering drop-link needs replacing
2. ABS dash light currently lit, I don’t think that it’s actually the ABS unit that is faulty, but a faulty brake sensor, as the brakes don’t lock up, or not work as they should.  Will be looking at this as soon as I can ?.
3. Could do with an oil & filter change, as it’s about due for one, as the follower are starting to sound tappety now, so think it’s a sign that the oil needs a changing !.
4. Rear wheel arches right at the back edge / corner starting to show signs of surface rust.
5. Auto gearbox has slight fault, but nothing that effects the day-to-day use of, think it is the 1st to 2nd solenoid (from memory showing as fault code P1851), and been like for around 18 months.
I know it’s a very long advert.  But I’m being as honest about the car so you know what you would be getting.  And I would prefer if you’re interested in it, to come and view it to satisfy yourself before parting with your hard earned cash.
Asking £1,100  (or PM me with sensible offers, not via the thread please)
Any questions, please PM me, not respond to this thread – Thank you.
Regards,
Goose  :)
SJKOO01
Re: FOR SALE - Omega 2001 2.2 Auto Saloon
« Reply #1 on: 16 October 2010, 15:58:59 »
**** UPDATE ****
ABS dash light - Problem has been traced to faulty wheel sensor, which will be replaced shortly.
So it is confirmed that it isn't the ABS ecu.
This has been checked, and confirmed by Wellung on here, so I know it's been checked corretly  :y  - Rather than done by a local garage whom I don't know  :-/
Single din mid-range spec Sony cd/ radio has been fitted - So you can have something to listen to now.
It is slightly faulty as it doesn't tune into Radio 4   ::)  ;D  ;D
(Just kidding, it works fine)  :y
« Reply #2 on: 17 October 2010, 01:12:26 »
Excellent add, nice detail..... :y
Some pics about the radio change would be beneficial.... :y
Welung666
« Reply #3 on: 17 October 2010, 01:32:28 »
It's one of those annoying gay Sony's that beeps when you turn the ignition off ;D ;D
SJKOO01
« Reply #4 on: 17 October 2010, 12:23:02 »
Thanks for the positive comment about the advert Vamps  :y, I'll try to add some picture of the interior later tonight, mind you I've had no interest, so obviously after all that effort, it hasn't paid off.  So I'll have to advertise elsewhere me things ?!  :-/
Lee,
Your right it's &%^*£$ darn annoying that it tells you every time you leave the car.... hey you've forgotten to remove the stereo front... >:( .
But like I said it was given to me "Free"  ::) , as my mate thought it was faulty due to it doing that..... So I'm not complaining - least it wan't a gay pink one that I was given  ;D  ;D  ;D  ;D    :y
SJKOO01
« Reply #5 on: 17 October 2010, 18:39:28 »
Additional photos - Seats & Centre console
[/img]
