Anyone need tractor engine parts
Started by TheBoy, 10 April 2009, 12:08:44
Quoteanyone want anything else?
All I'm after is the bracket that holds the a/c pipe to the side of the engine (front of engine near top) the pipe runs down the left side.
If in doubt at what it is I can post a pic up.
Ordered one from dealer last year, but I think they don't have or know what part it is.
Mick
pretty certain that went yesterday, but I will check the big box (Odds and ends I kept as I though may be useful).  Failing that, easy enough to make something up...
Ian_D
QuoteHas this gone to the tip yet?
Could be after the aircon belt + pully if you have it still...
Other than that, I cant think of anything I NEED. ;D
Most of the small bits went to tip yesterday (Towcester tip, skips are on level ground, so pointless taking heavy parts - I'd never lift them ;D).
No belt, but I think I still have the pulleys. The pulley sizes vary, so ideally need a matching pair.  I have the crank A/C pulley, and a matched A/C compressor (I'll let you take the pulley off that ;D).  Also got the crank aux pulley - the one with the damper in. These fail occasionally, you're welcome to that as well. Let me know, and they will be put to one side
I need to go look at the tractor and see whats actually caused the belt to melt itself! I guess the idler pully has seized up maybe as its the outside of the belt which has melted.
[move][size=12]
[color=#ff0000] LMF are utter rubbish - dont buy steering idlers from them! You've been warned![/color][/size]
[/move]
Ian_D
QuoteThe crank should make a nice garden ornament.....you could turn it into a water feature!
i hate garden ponds with a passion.  No idea why, always have....
That will have to wait for a trip to Ardley tip, as they have sunken skips, so stand a chance of being strong enough to throw it in ;D
Hmmm, Wonder what my mum would say if she had a diesel crankshaft sticking out of the middle of the pond  ::)
Theres only one way to find out! [size=8]...Fight![/size]  ;D What do you reckon?  :D
[move][size=12]
[/move]
May have the idler pulley part, think thats on the shelf with compressor.
If you can make use of it, I'll try to bring it up to york.
Ian_D
Cheers Mate!  :y
[move][size=12]
[/move]
Cheers Mate!  :y
Remind me nearer the time what I need to bring up ;D
Ian_D
Righto!
You could also fetch them server HDD's if you dont mind?  :y
Plus any other computer / server stuff which you dont need!  ;D
Basicly, if its got a wire inside, I would take it off your hands!  ;D
[move][size=12]
[/move]
QuoteRighto!
Excellent, I have loads of crap I want rid of and can easily insert off cuts of wire into it all.
QuoteRighto!
I'll bagsie the plasma - that will sit nicely on my bedroom wall ;D
Any more bits needed.  I have managed to bin most of it, but a few ancillaries left.
Block will be down the tip when the useless student gives me a hand to lift it ;D
QuoteAny more bits needed.  I have managed to bin most of it, but a few ancillaries left.
Or shall I use it as a flower pot
:o
Nah, tip I think is best option ;D
Few hoses, boxes, injectors left - free to anyone to collect or use OOF postal service ;D
The glovebox I think is from Astra-G with the CDC3 and telematics cutouts.  The blind, from memory, works OK, but when bringing down, grinds for about a sec after it is fully down
Complete loom from U25DT engine
Few coolant bottles from V6 and tractors, all with no level sensors
A/C Condensor - looks OK, but condition unknown
richy08
TB i might have that inlet manifold off u but wont be able to make it down till next week plus u might stick that tech 2 thing might find out wot up with that stupid car i got thanks mate richy
QuoteTB i might have that inlet manifold off u but wont be able to make it down till next week plus u might stick that tech 2 thing might find out wot up with that stupid car i got thanks mate richy
I have already given Unlucky Alf first option on that.  If he don't want it, its all yours.
Marks DTM Calib is probably closer for t2 work
unlucky alf
hi TB, just spotted this bunch of photos, anyhow i will take the manifold off your hands & is that plastic fan shroud off a tractor as i believe mine hasnt got one :D
