Breaking prefacelift mv6 1998
Started by RobseyMV6, 04 May 2009, 18:20:59
Bumbazor
Hi, I read your PM first. Should have checked here before. I'll need the headlight washer pump with the bottle too if it comes without. I have all pipes. PM me with new price.
As I said I'll pass on the wheels but thanks for considering me.
RobseyMV6
woodsy_mv6
#17
Hi Rob.
How much was it you were after for the wheels?
Also, what kind of nick is the header tank in? Me rebuilds starting to come together now, and its the last thing on my list. Refuse to pay stealer prices for that ;D
This ain't the one you showed me a year or so ago is it, with the popped tensioners??
O', and never got to thank you and your misses for the bump start :-[
From the moment I picked up your book until I laid it down, I was convulsed with laughter. Some day I intend reading it.
RobseyMV6
Hi there! The bump start was at least some exercise for her  ;D
PM sent
going crazy
QuoteYes, PM sent  :)
Rob/ Marti,
Recieved the item today. Thanks again, hopefully I will figure out how to remove the window handle & get to replacing this over the w/e
Thanks,
Suhas
RobseyMV6
#20
No problem Suhas  :y
MV6Matt
QuoteI have a couple of 3.0 heads here mate and a set of 3.0 cams if the engine from this sells as a whole  :y
Can you use the 3.0 Cylinder heads in a 2.5 engine like the 3.0 litre cams?
....Or have I got the wrong end of the stick? :-[
(thanks Ian)
RobseyMV6
Ok still have the engine for sale, yet another time waster from ebay lets you down again  >:( >:(
doz
How much do you want for the engine loom? If it's not been cut etc?
924boy
#24
carbon fibre dash parts and door card trims available?
RobseyMV6
QuoteHow much do you want for the engine loom? If it's not been cut etc?
I`ve got several wiring looms, are you after the 3.0 auto?
PM sent
RobseyMV6
Quotecarbon fibre dash parts and door card trims available?
Yup, got that
PM sent
mikeh
Hi, do you have the drivers side door check strap and mechanism.
Thanks.
Sheepie
Hi mate can you pm me ur lowest price on teh engine please as i need 1 to save my car from the scrap yard
RobseyMV6
QuoteHi mate can you pm me ur (I'm just lazy, can't be bothered to type 'you are') lowest price on teh engine please as i need 1 to save my car from the scrap yard
Pm sent  :y
