Author Topic: WANTED: Headlight Switch  (Read 7258 times)
mervswerv
Re: WANTED: Headlight Switch
« Reply #15 on: 27 August 2009, 16:07:05 »
Have correct switch if you need it.
Ratty
  • Coventry
    • '99 2.5 CDX Mini-FL Est
« Reply #16 on: 27 August 2009, 16:09:45 »
Thanks mate, I'm supposed to be collecting one today, but if it falls through I'll get back to you.
Thanks :D
John
Ratty
  • Coventry
« Reply #17 on: 01 September 2009, 08:52:12 »
update on this...
Apparently I need a headlight switch with an Ident [size=12]MP[/size]
part number = 90566851 (and possibly 904379679)
as it appears it's specific to my chassis range :(
anyone got one? I think the Ident is more important so long as it has both fogs and the leveller.
Fingers crossed ;)
Thanks
« Last Edit: 01 September 2009, 08:53:18 by ratsalad »
John
AndyVXR300
« Reply #18 on: 01 September 2009, 11:15:54 »
update on this...
Fingers crossed ;)
Thanks
What year is the one you want from ?
i have 5 units here but all are
MT 90 566 846
with both fogs and leveller
Andy
WWW.VXRONLINE.CO.UK
Ratty
  • Coventry
« Reply #19 on: 01 September 2009, 11:18:07 »
1999 mini facelift
John
markey mark
  • SLady bitshorpe north lincs
« Reply #20 on: 03 September 2009, 01:04:15 »
should have one in my garage will have a look over next few days  :y
Ratty
  • Coventry
« Reply #21 on: 03 September 2009, 01:13:24 »
thanks I've been told that it doesn't make any difference what ident it is as long as it has the correct switches etc on it, but Vauxhall say that only the ident MP would work, I have a problem with my dash lights and I've got 2 switches here that are different Idents than my original switch and the dash lights still don't work, general consensus among those helping me to cure the problem is that it's a fault on the car, but if I can get the correct ident and part number unit then at least it eliminates the possibility that it's an incompatible switch.
« Last Edit: 03 September 2009, 01:16:41 by ratsalad »
John
bluehawk
« Reply #22 on: 03 September 2009, 03:41:54 »
 I will have a look as well as i have a 99cd going to the scrappys that had all the switchs you mention
Ratty
  • Coventry
« Reply #23 on: 03 September 2009, 07:04:11 »
Thank you :y :)
John
Ratty
  • Coventry
« Reply #24 on: 04 September 2009, 10:07:50 »
Thanks all...
I no longer need one :D
John
