Author Topic: traffic master 36 way loom and button wanted.  (Read 6576 times)
« on: 06 September 2009, 15:30:11 »
i have a silver tm box but need a 36 pin loom and button. Or if you have the plastic tm box as well ill give the silver box back to The Boy for his swap collection. Whatever. Anyone?
Welung666
Re: traffic master 36 way loom and button wanted.
« Reply #1 on: 06 September 2009, 16:17:57 »
The 01 2.2 I'm breaking has TM on Chris ;) :y
« Reply #2 on: 06 September 2009, 19:49:34 »
Ooh, good man, how much? And do you know how many pins in the plug?
Welung666
« Reply #3 on: 07 September 2009, 12:08:19 »
Where is the box and I'll tell you ;) ;D
    • 530D M Sport, 330i Coupe
« Reply #4 on: 07 September 2009, 12:18:29 »
Tied up under the drivers side dash, you need to drop the trim panel underneath the dash (with the slots in for the pedals)
« Reply #5 on: 07 September 2009, 12:59:14 »
 ;D ;D ;D thanks Andy.
Welung666
« Reply #6 on: 07 September 2009, 14:13:04 »
Thanks Andy :y I'll have a look after work Chris :y
Welung666
« Reply #7 on: 08 September 2009, 12:47:05 »
Here you go Chris....
« Reply #8 on: 08 September 2009, 19:13:47 »
Thanks, good pics. Er ..... Andy..... ?
Welung666
« Reply #9 on: 08 September 2009, 19:22:12 »
 ;D ;D ;D
Sticker on it says:-
TrafficMaster
194.0
73652112
20133330
Sticker on the Male ISO says:-
Hallenday Ltd
Tested OK
Batch OM5380
« Reply #10 on: 08 September 2009, 19:36:41 »
Yep that's the right loom and Omega TM switch (Might be worth getting the light switch surround as well to save you drilling a hole!)
TM probably better using a TB silver one and using the antenna you already have.
Welung666
« Reply #11 on: 08 September 2009, 20:03:16 »
What antenna? ;D I thought it was internal?
« Last Edit: 08 September 2009, 20:03:40 by Welung666 »
« Reply #12 on: 08 September 2009, 20:10:40 »
Great stuff, thankyou guys.
Yeah makes sense re the surround to save whole drilling. Assuming it is the usual grey colour?
only leaves the price i guess.
Pm to follow Wellung. :-)
Should explane my concerns with the loom. I have 2015 head unit which was designed to work with tmc, which does not work in the uk. So in the interest in some clue to m4 traffic on my commute best option seems to be traffic master, for which no loom exists for 2015 as plug and play as understand it. So need to mod it (will need help with that no doubt ::) ) to work with my head unit.
So thanks guys, not laid eyes on the wiring before so appreciate both your help.
« Last Edit: 08 September 2009, 20:17:57 by chrisgixer »
« Reply #13 on: 08 September 2009, 20:15:46 »
i have a silver tm, older model i assume, which has an aerial connector as well.( two wire cable with the wires spread at the end to give, er, an aerial  :-/ just sits behind the dash)
Welung666
« Reply #14 on: 08 September 2009, 20:20:44 »
I'm guessing this one is internal then, I can't tell without splitting the box which would break the warranty seal ;D
