Breaking a 1999, 3.0 Elite in Z359 Green
Started by Loo-knee, 20 August 2009, 21:13:26
Ziad
QuoteIn which case I owe Ziad an appology, sorry mate :y
No worries there mate and no apologies needed.  :y Sorry for the bad english  :-[
Cheers
Ziad
I could not spell one word of your language mate  :-[ you are doing excellent :y
Well, believe it or not, i'm not from Bahrain originally. I just moved here like a year ago. I'm from Mauritius actually and the mother tongue is a derivative of french. So, from time to time, i tend to literally translate from french to english  :P :D
Show off  ;D ;D
;D ;D ;D  :y
kevinminton
Daz - pair of rear springs available?
Darth Loo-knee
I_want_an_Omega
Hi,
I'm interested in the headlight washer system. I think its the tank/pump from under the front bumper - together with pipes etc upto the headlights. There is also one of the relays required from the under bonnet fuse-box.
I dont need the headlights themselves, but do need the washer jets/nozzles.
Thanks .......... Rob
Darth Loo-knee
#34
3.0 Cams with Inlet Sandwich Plate = £100 posted
3.0 Heads £60 posted
3.0 ABS ECU = £40 posted
3.0 Throttle Bodies = £25 posted
Inlet Manifold with Injectors & rail (ideal for someone doing Gas Conversion) = £20 posted
Drivers Side HID Looks Brand New = £45 (dont like posting these)
Engine Undertray = £20 posted
Radiator = £25 posted
Air Con Condensor = £25 posted
Field Vision Arm (fits on passenger wishbone) = £15 posted
Rear Multi Ram Solenoid = £12 posted
Rear Self Leveling Shocks = £50 posted
Front Suspension, Shock & Spring etc = £25
Rear Bootlid everything on it = £35
Rear Shelf with Bose Speaker Covers = £35
Both Wings are in Excellent Condition = £10 each
Passenger Door has No scabs = £35
Rear Passenger Door No Scabs = £25
Auto Gearbox (AR35) = £70
Sat Nav = £50
Bose Sound System = £80
Everything must go, so if it ain't on the list please PM me ;)
roadrunner0180
hi, i don't suppose you still have the radiator do you.
my omega elite has the silly 2 radiator set up, but the one at the very front of the car, is for the air-con, but thats ok.
the one i need, is the normal engine cooling rad, that sits just in front of the engine itself.
the part number on the silver tag, by the pipes, on the drivers side is: DG 52463050.
MY MOB NUMBER IS 07506191900, OR LEAVE ME A REPLY HERE, AND I WILL EITHER COME AND GET IT , OR PAY FOR IT, AND ARRANGE A COLLECTION. UNLES, YOU CAN ARRANGE A DELIVERY FROM YOUR END, AND TELL ME HOW MUCH ALLTOGETHER.  THANKS. :y
Xplicit 2.0
Loo-Knee, PM sent with regards to bumpers :)
Darth Loo-knee
Quotehi, i don't suppose you still have the radiator do you.
I have PM'd you mate :y
Would remove your phone numbers though mate ;)
Gurthang
Hi first post lol
will ur sat nav fit 96 estate ?
ollied
QuoteHi first post lol
will ur (I'm just lazy, can't be bothered to type 'you are') sat nav fit 96 estate ?
It will, but you may need to extend the loom, find a different way to mount the CD/ECU box, and do an awkward connection into car loom.
Does look it good condition to break, but not easy to tell from photo.  But then, it will help keep other Omegas running cheaply :y
Darth Loo-knee
goonv6
Have paid you for the estate Bose system. Can't wait for this one! Where does the amp locate? :y
Darth Loo-knee
#44
QuoteHave paid you for the estate Bose system. Can't wait for this one! Where does the amp locate? :y
In the boot, in the pull down flap on the N/S ;)
Could do with you PM'ing me with your address so I can post it too you :y
