Author Topic: Estate rear wiper Arm  (Read 2955 times)
Andyb
  • Lincoln
« on: 28 February 2010, 08:51:14 »
has anyone got the above has to be in good condidtion and the spring needs to be strong
as my one dont sweep all the screen any more
pm with any thing inc price and details
Many thanks
Andy
kcl
  • Finland
    • Volvo V60 D4 -14
Re: Estate rear wiper Arm
« Reply #1 on: 24 March 2010, 13:44:24 »
Don't have the arm for you but you must use genuine GM blade which is curved to fit the rear screen... that has helped so far :-) Of course your arm can be damaged and worn, but the wrong blade is the problem in most cases
MV6Matt
  • London
    • No car since 2022....
« Reply #2 on: 24 March 2010, 16:37:18 »
............nowt to do with the blade (GM or otherwise).
The arm and spring are the culprits here.
You need a new arm and spring to put the tension back and hold the blade down on the glass. I only use GM blades on the rear wiper
I replaced mine Oct 07 and it no longer holds the blade flat in the entire 'sweep' of the wiper. It misses the top of the glass on my car.... :'( :'(
Matthew
« Last Edit: 25 March 2010, 09:46:15 by MV6Matt »
(thanks Ian)
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #3 on: 24 March 2010, 16:55:35 »
Not that expensive from Vauxhall mate I bought one a few weeks back for Mrs. Loo-knee's car :y
Andyb
  • Lincoln
« Reply #4 on: 24 March 2010, 21:31:58 »
well i got to go there within the next few days for a few bits as per pre thread so another ££££ wont matter
pedroMV6
  • York
  • Der Metzgermeister
« Reply #5 on: 24 March 2010, 22:34:01 »
Looks better than standard - I should think it would clean better too, as I've never seen a bad Focus rear window, and they're like a goldfish bowl omega rear window.
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=180480725905&ssPageName=STRK:MEWAX:IT#ht_500wt_975
Hannah Judes Dad
    • the misses round the bend
« Reply #6 on: 25 March 2010, 09:28:43 »
That does look rather nice in comparison to what is on the back of my estate
MV6Matt
  • London
« Reply #7 on: 25 March 2010, 09:44:55 »
I think you're right Simon, it does doesn't it?
I know what to try when it needs replacing next! :y
(thanks Ian)
pedroMV6
  • York
« Reply #8 on: 25 March 2010, 10:39:57 »
Same here - but just ordered a new set of 3 flat blades.
There is a forlorn looking Focus down my street though...........
 :D :D :D
« Last Edit: 25 March 2010, 10:40:21 by PedroMV6 »
Andyb
  • Lincoln
« Reply #9 on: 25 March 2010, 16:38:05 »
ooooooooooooooooooooooooooooooh
i do like that a lot
decitions decitions
sod it might as well
MickAP
  • South Derbyshire
« Reply #10 on: 25 March 2010, 17:42:57 »
Try giving it a bit of lubrication :o
Mine was missing parts of the screen, until I freed it up a bit, still does but not as bad.
Mick :y
