Breaking: Champagne (Z489) Elite (Facelift)
Started by TheBoy, 16 April 2010, 16:55:53
QuoteDo you still have the wiper linkage/motor assembly ? and does it have less play than the one on mine. Or can the bushes in the arms be replaced ?
I will check - don't recall it being problematic when I was using the car...
If it's got less play than mine i'll have it. How much do you want for it ?
If you are passing, yours for £20 collected. Still on the car currently, so you can check before removal...
mrjimbo
OK   :y   I might be up that way on Friday or Saturday.
Budgie
QuoteHi,
Can you help with parts I'm looking for? - see link below.
Thanks
http://www.omegaowners.com/forum/YaBB.pl?num=1272815974
Any joy with these  :question
I spend far too much money on my Omega
jjleonard
Are you selling the headlights? i'm after the passenger side, with adjuster motor? (I'm assuming they're xenons, as it's an elite....)
QuoteAre you selling the headlights? i'm after the passenger side, with adjuster motor? (I'm assuming they're xenons, as it's an elite....)
Already sold, sorry.
Odd request, fuel lines......
But i'm guessing that the tank has fuel in.......
QuoteOdd request, fuel lines......
The tank is pretty empty - contents now in MV6, Kawasaki and lawnmower ;D
The metal pipes out of top of tank are passed their best.  No reason to suspect that the rest of fuel lines are not good though.
I will check which one it is and let you know tomorrow.  :y
Hi TB
It's the pipe furthest from the outside edge of the car, the feed from the fuel filter to the injector rail, guessing it will need to pull back through the inner wing from the rail. Mine is damaged on the connector in the middle so needs the entire run.....
Hi TB
Yours for nought if you want to come and take it off ;)
Excellent  :)
When are you planning to dispose of the car? I've got some time off 26th onwards or could run up one evening.
I know you said non-engine parts only... guessing this is because of it's running issue?
If the 3.0 cams are available, how much do you want for them? Not much that can be wrong with them  :y
( I could collect them at the same time I badger you for a gearbox/climate update  :D )
QuoteI know you said non-engine parts only... guessing this is because of it's running issue?
No engine parts simply because I hadn't got around to stripping the engine, and my back was giving me an awful lot of grief.
3l cams are out of car now, sat in an oil bath.  Divider plate still on engine.
£100 collected, no offers, first to bring the cash to me and pick them up will be the owner of them ;)
Eric DUBLIN
QuoteAll non engine parts available.
Hows it goin TB!  im after; rear shocks and springs, and new front struts for my 2.5td. Any salvage from champagne  or  Any suggestions?
                Nice'1 :y
                              Eric.
                Nice'1 :y
                              Eric.
The suspension on this one would have been changed if I didn't break it, as its passed its best.  Therefore I would suggest to look elsewhere, sorry.
