Wanted! A few things I can't get in the US...
Started by WGoins88, 18 August 2010, 17:00:52
gstylebaby
WGoins88
#16
Yeah, I can't believe I found all that stuff that I needed. The cam bolts are the only thing I can't find. I know they have to be available since they are torque to yield and can't be reused.
Can anyone here confirm that this is the part number for the Cam gear bolts?
90573287
1997 Catera - 75k miles
Vplatform.forumer.com
WGoins88
Adding one more thing.....
Exhaust donut gaskets (Ones that go between manifold and downpipe).... they are ungodly expensive here.
WGoins88
Alrighty... well all I need now is the exhaust flange gaskets ($14 USD a piece here!). I found the cam gear bolts at a local import shop..... he happened to have 2 sets of 4 there because someone had requested them in the past for a Catera. Only $4 USD per bolt.
Welung666
Are you still after an Opel grill for your Cat? I have one here if you fancy a swop ;)
WGoins88
I certainly would like a Opel grille. However someone told me that the Catera grille is larger and needs bumper modifications, but I'm not sure on that... If you measure the Opel grille and take a picture, I'll do the same.
