'00 2.5 auto Elite green (z380) estate. Breaking.
Started by Brikhead, 09 November 2010, 09:40:12
QuoteHow much for the tailgate spoiler?
As said, £40, comes with free tailgate attached!!
Seriously tough, are they not glued on? If they are and you want to come and un-attach it then you are welcome to it, providing they come apart with no damage then you can have it for twenty squid...
...which is a bargain for a genuine ProDrive spoiler. :y
Sikoflex and two screws I think which would render the tailgate worthless. However I have no room for a tailgate here...
pedroMV6
Rear bumper - is it just scraped and in need of paint, or has it been bashed and now mis-shapen?
I'd want it complete with the tow hook cover too, please!
Hannah Judes Dad
Are the wheels up for grabs and if so how much?
Brikhead
QuoteHowever I have no room for a tailgate here...
Is your car the same colour? You would be welcome to pop round and I could help you to swap over the complete tailgate?
QuoteRear bumper - is it just scraped and in need of paint, or has it been bashed and now mis-shapen?
It's had a bit of a bash on the n/s, nothing too bad and the bumper still fits the car nicely with no broken fittings... £15 complete, collected.
QuoteAre the wheels up for grabs and if so how much?
Yep, wheels still available. I'd like to think they are worth £250, they come with matching tyres that are wearing evenly and have loads of tread left...
I consider this wheel to be in the worst condition out of the four, although I have yet to remove them to check them thoroughly...
gstylebaby
QuoteHi mate will the side bits in the boot with the storage box's on fit a pre face lift if they will how much do you want for them and the back wiper arm.
Thanks.
Lee. :y
Not sure to be honest Mate. Knowing Vauxhall, and judging by how similar the inner sill trims are on this vehicle to the ones I sold you off my pf/l, then I'd say they are the same...
I've just removed the n/s boot trim (undamaged with all the clips still attached) and was thinking of trying to convince 'unlucky alf' to convert his beige boot into a dark grey one!
As for price, these bits are in the way and will soon become
dirty or damaged, I only want a fiver for each piece of trim/carpet, excluding the load cover and rails, but if you need me to post them then I'll have to charge forty squids on top... it's a lot of hassle packaging large plastic trim pieces and sending them through the post, it's much easier to send a diff, for example, via a courier than it is to send large pieces of trim with RoyalMail...
Rear wiper arm's a fiver, btw...
P.S. How come you have the time to be worrying about car parts!?
Hi mate,
I'm trying to find out if they will fit. Not sure if i'm going to take them or not yet mate.  I know what you mean about the postage of big stuff with post office and i'm not sure were you are so i could pick them up it mite cost me about the same in juice  ;D  ;D.  Plus i suppose i dont need them that much but thought they would be handy to have.  Oh the rear wiper is that £5 posted or is that extra  :-/ :-/ just checking.
I'm at work so i can get abit of time to check out stuff that i'm after or thinking about for the motors.  Other wise if i was at home i would be to busy to even think about car's. ;D ;D ;D ;D
pedroMV6
OK, cheers matey. I could do with a bump-free one for th etruck, to be honest. Thanks anyway. :y
less
Hi Brikhead, Is the gearbox a known good box? (were you using the car or just bought it in?)
Mine has failed and a filter/oil change has not fixed it, so I need a known good box to make it worth proceeding with a repair.
Brikhead
QuoteHi Brikhead, Is the gearbox a known good box? (were you using the car or just bought it in?)
Hiya Mate, the car has not been used for a while, that said I have moved it back and forth and the box seems to operate normally. No fault messages up on the dash either.
Why not take a chance? You can have it for fifty squid, thats assuming you need me to remove it and prepare it for collection by your courier...
Cheers, Rich.
Brikhead
Spare wheel and tyre with good tread. The rubber looks to be in good condition with no decay but who knows how old it is. £15.
Witter G68 towbar.
All parts included.
No bumper cutting required.
Suits lowered or standard height suspension.
Easy to fit in just four steps as the holes are pre-marked in the boot floor from the factory*.
I've left some of the vauxhall wiring loom attached so as you can identify how to wire it in to your vehicle.
£45.
*fitting instructions here...
http://www.witter-towbars.co.uk/uMedia/FittingInstructions/G68.pdf
mrjimbo
Do you have the wiring loom for the rear seats ? the section that goes from the main loom connector under the rear seat on the passenger side to the seat connectors and runs along the seat support and has the 2 relays in it. I need that section of the wiring with the relays and clips if you still have it  :y
Welung666
Can I have the exterior door handle from the rear door drivers side? Mine is breaked and the colour is close enough for me for the moment until I can find one in the correct colour :y
Brikhead
QuoteDo you have the wiring loom for the rear seats ?
Some-one else has first dibs...
http://www.omegaowners.com/forum/YaBB.pl?num=1288637914
...but I'd rather sell them as part of the front and rear seats.
If I have to split them then I'd have no idea what they were worth.
QuoteCan I have the exterior door handle from the rear door drivers side?
Sure can... I tried charging a tenner each for the ones off of the Mv6, I guess that was too much 'cos I've still got all four!!!
How does £7.50 sound?
Saying that, are you sure your colour isn't amongst these?
http://shop.ebay.co.uk/?_from=R40&_trksid=p5197.m570.l1313&_nkw=omega+door+handles&_sacat=See-All-Categories
Welung666
Mines Z359 Jungle Green Mica, none on eGay and yours isn't too far away as a temporary measure until I can get one in the right colour. Can I have it with the zinc backing plate to? :y
Brikhead
QuoteCan I have it with the zinc backing plate to? :y
Yes Mate, all included...
P.M. me if you need my phone number to arrange collection.
Few other bits removed today...
Complete drivers side cubbyhole, trim and air vent assembly.
Removed undamaged and in working order. £10.
Door cards with fittings and fixings. £5 each.
Dash switches in good condition.
Heated seat switches £5 each.
All others £2.50 each.
Climate panel. 'ECO', heated rear screen, all three direction buttons and the two temperature dials are all unmarked. £10.
The stereo is damaged, the entire front panel has become detached from the surround, it was like this before I started to remove it... Also the previous owner said that the C.D. player doesn't work, whether this is because he didn't have the code I don't know.
The radio works fine, I didn't bother to check the tape player but I did eject and re-load the c.d. magazine, little flap on the front panel is working fine. Includes metal cage and can also include the plastic cage that holds the metal one, if needed.
£25.
Brikhead
Bose audio system.
Includes front door speakers, rear door speakers, dual coil subwoofer, amp, wiring loom from drivers kick panel to amp and wiring loom for sub box.
All carefully removed with no cut wires, damage or broken clips.
£65 collected.
