Author Topic: General Starting problems......Help  (Read 3029 times)
Re: General Starting problems......Help
« Reply #15 on: 08 August 2007, 09:56:13 »
Sounds like a set of noid lights might come in handy to see if the injectors are firing...
http://www.abbeypowertools.co.uk/car-service-tools/car-electric-testers/showitem-8029-57798.aspx
Although car batteries are pretty safe if you're careful not to short them, modern HT systems are a bit nasty. If I need to check for a spark I generally wire a strobe light in series with a plug and aim it through the windscreen so it's visible when cranking rather than doing the old trick of holding a plug against the block.
I used to shrug off electric shocks as an occupational hazard but now I'm a lot more careful in my old age ;)
