Author Topic: Aluminium Adjusters Advert  (Read 95090 times)
Sparkesandnoise
  • Southampton
« on: 07 May 2010, 13:41:47 »
Aluminium Headlight Adjusters For Vauxhall / Opel Omegas
Post 1998 headlights (manufactured by Hella) have a plastic internal adjuster which is made from a material called PBT and is highly prone to breaking.
Once the adjuster has snapped the headlights can 'bounce' or 'wobble' and don't point in the correct direction. if this has happened to you I'm sure your aware how annoying it is! This could also result in an MOT failure.
The GM group or Hella do not make this component as a spare part, headlights with broken adjusters need the complete unit replaced at a large cost.
The broken internal adjusters can be replaced with the aluminium components sold here.
The components are machined from aluminium alloy billet and are supplied as singles, enough for one headlight. The parts are a slightly different shape from the original, this was done to ease machining and hence reduce the cost. Although the shape is slightly different they will work in exactly the same way but they are much stronger in both their design and the material from which they are made.
The adjuster is good for one headlight either driver or passenger side they are £12 each and are shipped first class recorded delivery (£2.00 to UK mainland, £10 Worldwide). The postage cost is the same how ever many parts you need.
A detailed description for fitting the parts can be found HERE
The fitting procedure is simple, if you follow the instructions, to change the adjuster in a single unit took me about and hour.
If you want these parts either PM me or email me at gad74@talktalk.net
« Last Edit: 07 May 2010, 13:51:04 by Mark »
Lampynoiseboy
  • SE Essex
  • pay no attention to the man behind the curtain
    • '51 3.2 Elite "Floozy"
Re: Aluminium Adjusters Advert
« Reply #1 on: 19 May 2010, 10:21:18 »
Looks like an excellent product. Can I assume that this will cure the really annoying warning "headlamp range adjustment" that I get every time I start my car? I think mine may have had some front end damage at some point in it's history, as the fixing on the top of both H/lights is damaged....
Trouble strikes in series of three's, but when working on the car, the next job after a series of three is not the fourth job -- it's the start of a brand new series of three
« Reply #2 on: 19 May 2010, 17:25:56 »
No, will be a sensor, wiring, or motor issue.
These cure the headlight reflectors flopping around.
Jack-V6
  • Netherland
    • omega Y2.5DTI 2003
    • opel omega portal
« Reply #3 on: 05 June 2010, 22:34:05 »
I bought a set of 2 and i must tel these are fantastic.
It even fits on depo lamps.
Gr Jack
« Reply #4 on: 09 August 2011, 13:59:56 »
Sorry if you've tried to PM me about these, the forum isn't forwarding messages to me for some reason.
If you want these parts just email me your paypal email address and the number of parts you want to gad74@talktalk.net, sorry for any delays.
Gregg
« Reply #5 on: 04 October 2017, 13:04:56 »
Sparkesandnoise no longer appear to be trading here on ebay,
You could try here : https://sites.google.com/site/sparkesandnoise/Our-products
Although ring them first, as the email address bounces.
There are also some alternatives on ebay
« Last Edit: 04 October 2017, 13:17:59 by Jimbob »
Re: Headlight adjusters
« Reply #6 on: 04 June 2018, 11:33:57 »
If using resin stylee, a good lubrication with silicone spray helps,and silicone grease.
Thanks, mate, but just ordered the aluminium ones from sparkesandnoise, as suggested by amba.  :y
Out of interest, how did you get in touch?  afaik noone else has been successful contacting them.
I found their website here and ordered with PayPal. The adjusters are listed on the left below the BMW bits. Haven't had an acknowledgement yet, but it is the weekend.
Cheers,
Please keep us posted with progress.
Ive been unable to get in touch with them, hope you get your bits.
Phoned today and discovered that the person who made the up sadly passed away a couple of years back.  :'(
The chap I spoke to said he'd passed the drawings on to someone in Norway(?).
Anyway, I'm back to square one. Will cancel the PayPal as the person I spoke to cannot access the account.
All seems a frightful hassle and I think it may be worth my while just getting new headlights. Time is money as they say.
Anyone reckon these would be any good? ???
https://www.motor-doctor.co.uk/products/8356453-headlight
Page created in 0.023 seconds with 20 queries.
