Author Topic: Wanted - Stainless Exhaust system for 3.2 Saloon  (Read 1647 times)
« on: 22 August 2011, 14:22:11 »
As per title. Anyone got anything?  :y
Re: Wanted - Stainless Exhaust system for 3.2 Saloon
« Reply #1 on: 22 August 2011, 14:26:58 »
When Rob was @ my place he mentioned probably selling his Powerflow twinpipe backbox
http://www.omegaowners.com/forum/YaBB.pl?action=viewprofile;username=44335D3B4E4445020
Similar/same as this
http://www.omegaowners.com/forum/YaBB.pl?num=1313694038
« Last Edit: 22 August 2011, 14:27:54 by RobG »
    • 530D M Sport, 330i Coupe
« Reply #2 on: 22 August 2011, 18:36:06 »
You can buy mine when I get round to fitting an Eternal system.
« Reply #3 on: 23 August 2011, 10:16:03 »
How come you're swapping a stainless for an eternal? :\
« Reply #4 on: 23 August 2011, 13:46:15 »
Because the Stainless one goes from two pipes to one (which I have tried multiple times to get sorted but the Long Life branch I used fall far short on the customer service).
The net result is I feel the car is a little 'flat', so I want to go back to a properly designed system, the only bit that anyone see's is the tailpipes... well being a facelift i'll have to add some poundland ones onto the system anyway so it clears the bumper!
You can have it for whatever it costs for an Eternal system if you want it!
« Reply #5 on: 23 August 2011, 13:59:56 »
Hmm... can you define flat? I don't really want to restrict mine  ::) :y
« Reply #6 on: 23 August 2011, 14:09:31 »
The flatness is not uncommon AFAIK... There must be a reason that Vx designed it with twin pipes for the full run of the vehicle ::)
The Jetex system (off the shelf) is twin pipes for the full length but I fear it may be too much of a drone so I'll likely be staying on the eternal path too
« Reply #7 on: 23 August 2011, 14:29:17 »
Flat as in not as responsive as a genuine GM system, putting this down to dual v single pipes.
blackviper90210
  • Bromsgrove, West Midlands
    • 03 3.2 Elite Saloon
« Reply #8 on: 23 August 2011, 14:48:17 »
I got a powerflow system off 2woody on here for mine. Its twin pipes all the way and sounds really nice. Not loud, but just gives a nice low down growl   ;D
AKA - Mr Bracket
