Author Topic: New member  (Read 6061 times)
jimatMK
  • MILTON KEYNES
New member
« on: 27 October 2006, 20:54:13 »
Hi All,
My name is Jim and I am  a new member.
I have just purchased my first Vauxhall since the 1970's. Since then I have always driven Fords. My last car was a Ford Granada Scorpio 24v Cosworth.
But I thought I needed a change so I bought this week an Omega MV6 Elite 3.0 2000.
Its done 50k miles and I would like your advice on a few aspects.
As far as I know the cambelt hasnt been changed so that is my first job to be done. I have had a quote from my local Vauxhall dealer of £320. Do you advise to have this done at a main dealer or would it be OK for a smaller garage to do the work for a cheaper price?
The car was fitted with Satnav from new but only has the original CD-ROM. So I want to update to the latest disc but have been quoted £95 by Navteq.Is there a cheaper way of doing this? Does anyone else supply these discs cheaper?
Any info will greatly appreciated.
Bo Bo
  • Coventry
Re: New member
« Reply #1 on: 27 October 2006, 21:10:44 »
Hello & welcome  :)
Try posting your questions in the help section, you'll get a better response there  ;)
Cav9_4
  • Sutton-In-Ashfield,Notts
  • 2003 Omega 2.6 Elite
Re: New member
« Reply #2 on: 27 October 2006, 22:40:53 »
Hi & welcome to the forum :y
Re: New member
« Reply #3 on: 28 October 2006, 00:46:56 »
Hi Jim and welcome :y
bob.dent
  • Hertfordshire
  • Drives better than an Omega
    • Mondeo 2.0TDCI Estate
Re: New member
« Reply #4 on: 28 October 2006, 01:36:35 »
hi Jim and welcome to the forum.  :y Make sure you get the cam beld AND tensioners sorted. £320 quid is far too expensive :o :o
Try a decent independent garage ;)
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
Re: New member
« Reply #5 on: 28 October 2006, 11:47:48 »
Hi Jim
welcome to the site - have a look around and enjoy.
Cambelt - an essential job on any car but even more so on omegas. £320 is a bit dear indepandant. Shop around and ensure its cambelt as well as tensioners ( the important bit on an omega as they are more prone to failure)
Or do it your self, hire a cam locking kit, buy the £3 dvd on here and ask if your unsure - you will get it done and you will get assistance from us :y
« Last Edit: 28 October 2006, 11:48:35 by Markiec »
MikeDundee
  • Costa Del Peckham
Re: New member
« Reply #6 on: 28 October 2006, 17:58:22 »
Welcome to the forum Jim 8-)
Big Steve
  • Coventry
Re: New member
« Reply #7 on: 29 October 2006, 10:30:16 »
Hi & welcome :)
IT'S AN OMEGA JIM BUT NOT AS WE KNOW IT
Re: New member
« Reply #8 on: 29 October 2006, 21:14:58 »
Hi m8 and welcome to the forum :y
RossPhim
  • Morayshire, Scotland
  • The blue oval now-a-days!?!
    • 2.2 TDCi TXS
Re: New member
« Reply #9 on: 30 October 2006, 07:40:59 »
Welcome to the forum Jim.  :y
The Barge Captain
Re: New member
« Reply #10 on: 30 October 2006, 11:12:41 »
Hi Jim and welcome to the forum
nixoro
  • Hitchin, Herts
Re: New member
« Reply #11 on: 30 October 2006, 11:29:45 »
Hi Jim and welcome to the site  :y
sounds2k
  • Queenborough, Kent
    • Saabs and a Jag XFR
Re: New member
« Reply #12 on: 02 November 2006, 22:02:46 »
Hi Jim,
welcome to the forum - does the car have a service history? It sounds very much like mine - which didn't - so I changed the cam belt and tensioners ASAP (they should be done every 40k or 4 years, whichever comes sooner). However I reckon the ones that were on there weren't the originals - but at least now I know it's definitely been done - and set up right.
Note that Vx have a target time to do the job in, so the timing won't necessarily be spot-on. At least one of the moderators on here had a flat spot (at 2 or 3k RPM) from when the belt and tensioners were done by Vx, apparently when they replaced them later (instead of Vx) a cam was found to be one tooth out - the replacement was fitted and timed up correctly and the flat spot disappeared ...  :)
Independents will probably charge about £250-ish to do the job, might be worth getting the water pump done too (about another £30).
Gwilym
  • Bridgwater, Somerset, UK
Re: New member
« Reply #13 on: 07 November 2006, 18:08:38 »
Hello and Welcome to the site
White '00 3.0 MV6 Estate (Ex Met Police Firearms Car)
mijfife
  • Rosyth, Fife. Scotland
  • AAARRRRGGGGGGGGG, IT'S WAS ONLY A GLS!!!!!!!
Re: New member
« Reply #14 on: 07 November 2006, 18:13:34 »
From one Jim to another, hello and welcome  ;)
Cheers Jim
The fleet consists of a Singer Chamois Coupe, an Imp based kit car - BS Nymph, and a Kawasaki GPZ 900R (& a Toyota RAV4 LPG for the work horse!)
