Author Topic: New member & thanks for excellent tech section  (Read 6172 times)
Chris W
  • Scottish Borders
« on: 27 September 2008, 20:51:15 »
Hi all. Just joined a couple of hours ago and you have just saved me a lot of time and effort with my crank sensor change. I was about to remove the oil cooler pipes and exhaust down pipe to fit a new sensor. The tech section is fantastic. Job competed in 30min after reading tech help.
I have had my  Y reg 2.5CD estate(very last of the 2.5's) for 4 years. It only had 29k on it when I bought it and now has 70k. Had lots of problems. I do most of the work myself. Cam belt was a bit of a hold your breath moment when i first turned the key on a 40k engine. I had a burnt out clutch (my own fault) VX dealer advised new flywheel also reqired for a cool £900!!!! £25 scrap yard flywheel did the job. Despite the problems love the car. It carries 8x4 sheets of plasterboard when required and can  head to France each year with 3 kids and all the lugage and i can still see out the back.
Look forward to chating to other members.
all the best Chris
Drive 2.5 CD Estate, 1.2 Corsa, Droop Snoot Firenza in bits in garage, bent Rally Magnum needing reshell. No time no money!!!
Re: New member & thanks for excellent tech section
« Reply #1 on: 27 September 2008, 21:07:22 »
Hello Chris and a very warm welcome to you! :y :y
less
  • Hemel Hempstead
    • 2.6 auto saloon
« Reply #2 on: 27 September 2008, 21:08:20 »
Hi Chris, welcome aboard mate  :y
« Reply #3 on: 27 September 2008, 21:15:24 »
Welcome to OOF Chris. - Did you route the sensor wire towards the inner wing and away from the exhaust manifold ? :y
Chris W
  • Scottish Borders
« Reply #4 on: 27 September 2008, 21:22:28 »
Hi albitz. Yes i followed the instructions and routed the sensor wire towards the inner wing and away from the exhaust manifold. I had been under the car thinking that I would have had to reinstall as per factory which would have taken hours!
Chris
dieseldean
  • chesterfield
« Reply #5 on: 27 September 2008, 21:24:40 »
welcome :y
« Reply #6 on: 27 September 2008, 21:33:19 »
Welcome to the site :y
« Reply #7 on: 27 September 2008, 22:03:34 »
Hi, welcome to the site.   :y
JueV6
  • Kent
« Reply #8 on: 27 September 2008, 22:37:51 »
Welcome to OOf. chris :y :y
« Reply #9 on: 27 September 2008, 22:43:42 »
Hi Chris, welcome to the forum :y
« Reply #10 on: 27 September 2008, 23:22:43 »
hi Chris from er ... Chris.  ;)
waspy
« Reply #11 on: 28 September 2008, 09:02:51 »
Morning Chris. Welcome along to the OOF  :y
HolyCount
« Reply #12 on: 28 September 2008, 10:45:13 »
Hi Chris, welcome to the forum -- good to see it's working for you already  :y
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #13 on: 28 September 2008, 11:07:53 »
welcome to the forum mate. :y
mars
  • Cannock, Staffordshire
    • Vivaro Sportive BMW 330d
« Reply #14 on: 28 September 2008, 11:51:10 »
Hi Chris and welcome :y
There is no such thing as bad beer, some beers are better than others.
