Author Topic: Intemittent engine failure  (Read 6179 times)
zip289
  • Norfolk
« on: 19 November 2009, 21:24:50 »
My OMEGA 2.6 V6 just stopped whilst I was driving it yesterday. Wouldn't start again (just turned over), then after 10 minutes or so it started, only to stop again a few yards down the road. AA man thinks its the in-tank fuel pump as he's seen this a few times with this model. Any suggestions? >:(
Re: Intemittent engine failure
« Reply #1 on: 19 November 2009, 21:26:13 »
Welcome to the forum :)
You would do better to post this question in the "General Help" section
http://www.omegaowners.com/forum/YaBB.pl?board=general
as more of the technical guys read there than here .. :)
have you done the pedal test ???  I'm thinking you might get code 19 ..
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
do the test and post up results in "General Help "
« Last Edit: 19 November 2009, 21:28:14 by entwood »
Welung666
« Reply #2 on: 19 November 2009, 21:27:03 »
Welcome to OOF Zip :y
This should really be posted in the general help section but as it's here.... click the link below my post and follow the instructions for the pedal trick and post the results in the general help section of the forum. My money's on crank sensor ;)
« Reply #3 on: 19 November 2009, 21:28:44 »
Welcome to the OOF mate :y
Welung666
« Reply #4 on: 19 November 2009, 21:30:25 »
Ent as it's a 2.6 it would be P0335 not a 19 ;)
« Reply #5 on: 19 November 2009, 21:35:45 »
Hello and a very warm welcome to you! :y
Stevie-blunder
  • Wolverhampton
« Reply #6 on: 19 November 2009, 21:52:45 »
Hi Zip, welcome to OOF  :y
« Reply #7 on: 19 November 2009, 22:06:17 »
Welcome along Z :y :y
sandune
  • Essex Southend
    • 2.6 Omega Auto
« Reply #8 on: 19 November 2009, 22:47:06 »
Hiya welcome aboard :y
Cliffo B
  • Leeds West Yorkshire
    • 03 3.2 Elite Estate
« Reply #9 on: 19 November 2009, 23:46:21 »
Hello,welcome to the Forum :y
« Reply #10 on: 20 November 2009, 01:57:58 »
Welcome to OOF mate :y
Is it a 2.5 or a 2.6?  Bet its crank sensor!
waspy
« Reply #11 on: 20 November 2009, 08:29:48 »
Ow do & welcome along :) :)
Hope you get the problem sorted. With the help on here you should :y
zip289
  • Norfolk
« Reply #12 on: 20 November 2009, 09:16:25 »
Thank you to all for your warm welcome, did pedal test and got a P0335 (crank shaft sensor) - see my full post on general help section
Thanks again, I'll never go to a garage again!
Zip289 :y
Elitenut
  • Redditch, Worcestershire
« Reply #13 on: 20 November 2009, 09:22:26 »
Hello and welcome to the Forum. :y :y
« Reply #14 on: 20 November 2009, 12:47:02 »
Hi and welcome ;)
