Author Topic: Tyre pressure and full rev range  (Read 4901 times)
Jay w
  • Plymouth/Poole
  • omega gone
Re: Tyre pressure and full rev range
« Reply #15 on: 29 August 2007, 20:23:51 »
i regularly introduce the rev needle to the redline, i has got to be done  :y
« Reply #16 on: 29 August 2007, 20:31:26 »
Winter tyres 32 front 30 back..
Normal tires 30 front 28 back... Long journeys  29 front  28 back (summer)
tried 225 km/h..if the measurement is OK.
« Reply #17 on: 29 August 2007, 22:32:10 »
I have 235/40/17's on the front and 265/40/17's on the rear and I had been running mine at slightly lower pressures since I had new tyres put on as the previous tyres (rears) had shown signs of over inflation by wearing in the middle. Big Rod (the previous owner) said he had normally run them at 30psi all round, so I've been running them at 28psi.
Since then I noticed my mpg reduced to around 22 on average to and from work. I checked my pressures last night and they were slightly down on the original 28psi I put in a few weeks ago, so thought I'd try them back at 30psi as these tyres are a slightly softer compound than the last set. I reset my MID this morning and was amazed that after my 22 mile journey to work my average mpg had gone up to over 25.
It will be interesting to see what average mpg I get going to Newent this weekend. :-?
Dont forget tho Bob......the rears should be 3psi higher than the fronts on estates.....i assume that applies for your 265's as well.
I run my 225's 30 front and 33 back  :y
Tho my tyres take abuse......coz one min it can be just me in it......10mins later 4 15 stone passengers  ;D
I did once inflate to 33 front 36 back as a comprimise.......but overinflation wear started showing after a time.
With normal wheels and tyres I'd agree Dave, but the tyres that came off the rear were worn in the middle which would indicate over inflation. I'm going to see Tony at WIM tomorrow so I'll see what he recommends.
True. Change the tyre size and the contact patch changes in area so the pressure required will be totally different and it's best to experiment. With those hoofing great tyres on the rear I suspect the ideal pressure will be quite a bit lower on the back than the book pressure. It all depends, for each wheel, on the weight it's carrying against the area of the contact patch.
Taking the extreme example I've got 205/50/15s on my Westfield, which weighs in a tonne less than an Omega and I reckon about 17-18 PSI all round is the best pressure. I had to experiment a bit to arrive there. Putting more air in makes it feel quite taught and responsive at first, and you can go quite high on pressure with no ill effects but you realise that there's less grip if you push it, and tyre wear will eventually confirm it. If you go a pound or two under the ideal, it quickly gets a bit vague and tends to let go when pushed.
familyman
  • Sittingbourne, Kent
« Reply #18 on: 29 August 2007, 22:56:04 »
Does anyone other than me use bar instead of psi or am i getting to modern ;D ;D ;D
You came in that, your braver than i thought
« Reply #19 on: 29 August 2007, 23:01:04 »
Always used PSI for tyres and, although I'd use bar when talking about most other things I haven't got a clue what a sensible tyre pressure in bar would be :-/
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #20 on: 29 August 2007, 23:06:43 »
Ask Spongebob he's the baa expert.  ;D
TuBy's new whipping boy.
« Reply #21 on: 30 August 2007, 08:01:19 »
I use mm etc rather than the rubbish that the old timers use  :P, but still use PSI - 32PSI seems better than 2.1bar (or whatever it is)...
omegaman2
  • Kilsyth, Glasgow G65
  • cruise , tints, shinbuster,advanced drinking test
« Reply #22 on: 30 August 2007, 15:21:27 »
after holiday season i did not put pressures down  ( lazy ) 36f 42b for caravan, the ride was harsh and back tires were worn down to limit in middle but 000;s miles left side treads ...anyway 4 corners replaced and tyre man put 36 in each not to bad but i reduced to 30 allround and now have magic carpet ride smooth & quiet :y
dieseldonicely
« Reply #23 on: 31 August 2007, 00:59:55 »
Does anybody use here nitrogen..Think it better than air
« Reply #24 on: 31 August 2007, 09:33:07 »
Never tried it although my local tyre depot has a sign up saying they'll use it on request (for a fee).
Because it contains no water vapour the tyre pressure remains much more stable over a wide range of temperatures. Not sure tyre pressure is that critical on an Omega, nore does tyre temperature really vary over such a great range but it's useful in motorsport where you'll always be chasing the right tyre pressure and getting serious heat into the tyres at the same time.
I remember watching a documentary on a Le Mans team in the run-up to the 24h and they were chasing all sorts of suspension setup problems until someone noticed that the tyre pressures had gone to pot after a fast run. Turns out the tyre fitter had put moist air into the tyres.
« Reply #25 on: 31 August 2007, 13:22:33 »
Yep.Nitrogen is not effected by temperature changes like normail air..And I feel its more comfortable than air..Here the temperature changes in night and day and driving conditions change the tires for higher pressures and make the omega jump jump  :)
Crazydad
  • Germany
    • 2.5 V6 facelift
« Reply #26 on: 31 August 2007, 14:54:03 »
Up to now i have allways used nitrogen in all my vehicles, but the Omega has such a smoooooth ride that i
don`t find it necessary.
The only thing is i have to check my pressures more often, 2,3 bar all round low mpg nice ride
« Last Edit: 31 August 2007, 14:54:33 by Crazydad »
« Reply #27 on: 31 August 2007, 15:38:11 »
Interesting. I never knew it influenced ride quality. Maybe I'll try it next time.
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
« Reply #28 on: 31 August 2007, 15:59:34 »
Any thing to keep the MPG on the right side. How much is 2-3 bar in PSI?.
Thanks.
« Reply #29 on: 31 August 2007, 22:32:37 »
nearly 33.36 psi =2.3 bar
« Last Edit: 31 August 2007, 22:33:20 by cem_devecioglu »
