Author Topic: battery  (Read 6317 times)
tejags46
battery
« on: 02 April 2010, 20:36:27 »
I know this sounds dim, and believe it or not I have owned my car for 7 years, my battery is flat, do I remove it from the car to charge or not?
Re: battery
« Reply #1 on: 02 April 2010, 20:55:37 »
"Hello" and Welcome :)
Tech questions are best asked in "Omega General Help" as more of "them that know" read there !!!
If the battery is totally flat I would at least disconnect it. It may draw a large current initially and cause your charger to "spike" the voltage which, in theory, could damage car electronics.....
If it is just low, and you have an "intelligent" charger like the CTEK 3600 then it should be ok to just connect it up ...
That's what I've done without any problems ... but perhaps I was lucky .... :)
Welung666
Re: battery
« Reply #2 on: 02 April 2010, 20:59:53 »
Welcome to OOF matey :y
Re: battery
« Reply #3 on: 02 April 2010, 21:27:39 »
Hello and a very warm welcome to you! :y
sexydaz
Re: battery
« Reply #4 on: 02 April 2010, 21:36:26 »
howdo :y
tejags46
Re: battery
« Reply #5 on: 02 April 2010, 22:11:45 »
when i disconnect, the alarm sounds intermittently. is there anything I can do about that?
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
Re: battery
« Reply #6 on: 02 April 2010, 22:17:11 »
Welcome bud! :y
Re: battery
« Reply #7 on: 02 April 2010, 22:17:27 »
The powersounder alarm will sound ... to stop this .. loosen the 0v (earth) connection but don't remove it. Switch the ignition on, pause then off... remove the 0v (earth) connection within 15 seconds of selecting "off"
Re: battery
« Reply #8 on: 02 April 2010, 22:20:50 »
Welcome to OOF mate  :y
Re: battery
« Reply #9 on: 02 April 2010, 22:30:09 »
Hi & Welcome  :y
Re: battery
« Reply #10 on: 03 April 2010, 01:37:48 »
Hi, welcome to the forum.   :y
Cliffo B
  • Leeds West Yorkshire
    • 03 3.2 Elite Estate
Re: battery
« Reply #11 on: 03 April 2010, 02:36:35 »
Hello,welcome to the Forum :y
metalhip
  • Mansfield
Re: battery
« Reply #12 on: 03 April 2010, 08:40:17 »
Hello and welcome :)
sandune
  • Essex Southend
    • 2.6 Omega Auto
Re: battery
« Reply #13 on: 03 April 2010, 17:18:43 »
Welcome  :y
waspy
Re: battery
« Reply #14 on: 04 April 2010, 14:19:39 »
How do. Welcome :y :y
